Random noise
Willdat?
  • Replies 45
Most honda abs/alb systems the accumulator/pump/seals fuck out. Noise could be the pump trying to build pressure? I ripped my system out. Need new master cylinder and all front brake hardliners/prop valve
Sounds like that - I assume if I ripped it out I'd also lose 4WD?
It still works fine. Nothing electronic making it 4wd. The clutch in the diff only gets activated (disengages to make it 2wd) when you do a abs stop
All sorted - half a dozen 'skids' on gravel loading up the ABS and the squeal is gone. No fun at all was had finding out how well the 4WD hooks up in mud either...
