chris r Posted June 5, 2016 Share Posted June 5, 2016 Most honda abs/alb systems the accumulator/pump/seals fuck out. Noise could be the pump trying to build pressure? I ripped my system out. Need new master cylinder and all front brake hardliners/prop valve Quote Link to comment Share on other sites More sharing options...
Willdat? Posted June 5, 2016 Author Share Posted June 5, 2016 Most honda abs/alb systems the accumulator/pump/seals fuck out. Noise could be the pump trying to build pressure? I ripped my system out. Need new master cylinder and all front brake hardliners/prop valve Sounds like that - I assume if I ripped it out I'd also lose 4WD? Quote Link to comment Share on other sites More sharing options...
chris r Posted June 5, 2016 Share Posted June 5, 2016 It still works fine. Nothing electronic making it 4wd. The clutch in the diff only gets activated (disengages to make it 2wd) when you do a abs stop Quote Link to comment Share on other sites More sharing options...
Willdat? Posted June 6, 2016 Author Share Posted June 6, 2016 It still works fine. Nothing electronic making it 4wd. The clutch in the diff only gets activated (disengages to make it 2wd) when you do a abs stop All sorted - half a dozen 'skids' on gravel loading up the ABS and the squeal is gone. No fun at all was had finding out how well the 4WD hooks up in mud either... 1 Quote Link to comment Share on other sites More sharing options...
chris r Posted June 6, 2016 Share Posted June 6, 2016 Nice. It is quite fun "testing" them in gravel/mud 1 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted June 8, 2016 Share Posted June 8, 2016 A victory for internet diagnosis! 1 Quote Link to comment Share on other sites More sharing options...
