Goldsack's 1973 Morris 1300 Discussion
mtbtimr
without reading any of this thread
just do some super basic checks
Is there 12v at the coil.
Are your points actually opening? Check points gap etc
IE: Turn ignition on, with dissy cap off open the the points with a screw driver and see if there is a small spark between the contacts
but basicly, yeah, check your points gap
  • Replies 62
Keep up the great advice, im a complete novice so all of this feedback is very helpful. im grabing a mates multimeter this week so i can check a few things.
the cable from the battery to the solenoid gets very, very hot when connected, any ideas what would cause that??
Also if i am replacing earth wires, because they are pretty corroded and shot, can i just use standard insulated cable??
cheers
Could be a number of things.
Resistance is an electrical systems nightmare.
(To a point ) you want the biggest wiring you can get to reduce resitance and voltage drop.
Not sure what standard insulated cable is? Go to a parts shop and get some. Any decent shop should stock it on a roll and can be bought by the meter.
Or they also sell pre-terminated cables too.
If not get power/earth cables from a car audio shop..
The reason the cable is getting hot could be.
- dead/dying starter motor
- poor earths
- poor battery voltage/current
- solenoid issue
- crap wire conditions
Good luck.
