samsnz Posted January 24, 2015 Posted January 24, 2015 discussion thread for my project ae70 4age drop.fire away Quote
beachlander Posted January 24, 2015 Posted January 24, 2015 Oh you got those headers you bastard Quote
samsnz Posted January 24, 2015 Author Posted January 24, 2015 noooooooo did i snipe them from u? Quote
beachlander Posted January 24, 2015 Posted January 24, 2015 Nah. A mate told me about them and i couldn't find the post. Figured someone must of bought them Quote
samsnz Posted January 24, 2015 Author Posted January 24, 2015 o right all good then ha hoping they do the trick Quote
Dell'orto Posted January 24, 2015 Posted January 24, 2015 Why would you want to get rid of TVIS? Sick of the low end torque that it already lacks? 3 Quote
advokit Posted January 24, 2015 Posted January 24, 2015 +1 on removing the TVIS, you will sacrifice low end and gain nothing from removing it. Quote
samsnz Posted January 24, 2015 Author Posted January 24, 2015 yea general consensus on here and the google reccommends keeping it so itll stay on Quote
bennis Posted January 25, 2015 Posted January 25, 2015 if you need any spare tvis parts let me know, hoarding heaps of that shit for yonks 1 Quote
samsnz Posted January 25, 2015 Author Posted January 25, 2015 yea for sure man. is there any way to check its function while its off th car? Quote
Seedy Al Posted January 25, 2015 Posted January 25, 2015 Take vacuum line off it and suck on it, should make the flaps be all flappy 1 Quote
samsnz Posted January 26, 2015 Author Posted January 26, 2015 nice! ill give it a jam.when no ones watching.... Quote
pbaines Posted January 27, 2015 Posted January 27, 2015 Would only remove TVIS if you have some massive cams and a turbo. Otherwise no benefit. Â But in regards to the ECU, yes you can remove it without problems for sure Quote
slacker.cam Posted February 2, 2015 Posted February 2, 2015 You won't want to run a rising rate FPR with the standard ECU. You need a 1:1 ratio regulator. Quote
samsnz Posted February 3, 2015 Author Posted February 3, 2015 maybe i got my terms wrong. website says it rises at 1:1 ratio Quote
samsnz Posted February 3, 2015 Author Posted February 3, 2015 i thought that was rising rate. as opposed to fixed but i think i get what u mean Quote
