WTBorrow: Compression Tester - AKL
Thanks for all the offers guys, this is why I love os.
Yeah I've done the basic checks. I'm pretty sure the drop gear went as I was coming into Picton (AA dropped it off this morning) and then it lost oil pressure and is struggling to stay running now. Two things that i wouldn't imagine relate to each other.
I have one at the lockup in Otara. might head out there tonight no problem to swing over to botany
If you are heading out there tonight that'd be ideal. Wanting to sort this asap, bus lyf sucks
What  type of car?
If it's a FWD Bloody Large Manufacturers Cock-up (BLMC) the two things may be related.
A buggered gearbox would overheat the oil and send bits into the oil filter dropping oil pressure and the extra load would slow the car down especially in the lower gears if it's the lay shaft bearings or the drop gears.
