Rhyscar Posted December 30, 2014 Share Posted December 30, 2014 Don't rule out a screwed wheel bearing. They go pretty suddenly and have some strange symptoms I found when mine went (both went within 2000kms of each other and less than 500kms of being checked and being fine) They aren't a tapered seat bearing like most older cars so even when they are screwed they don't have any play in them. Only way to tell if they are gone is to take wheel off, do 2-3 nuts up to hold brake rotor in place then rotate rotor by hand with the other hand on the top control arm. If it's screwed you'll feel a rumbling vibration through the arm. This confused me for a while when they went all of a sudden (just outside te kuiti at 12 pm with snow falling) and had similar symptoms of rumbling noise when braking/cornering. 1 Quote Link to comment Share on other sites More sharing options...
Rhyscar Posted December 30, 2014 Share Posted December 30, 2014 So basically Ford didn't fix any of their shit brake issues since at least the ED (therefore likely at least the E series on) Sucks to have one of those fail barges. Might as well be your wife's Audi. The brakes are actually relatively good on these things. I've got new rotors and bendex ultimate pads all round and they work awesome. Quote Link to comment Share on other sites More sharing options...
kyteler Posted December 30, 2014 Share Posted December 30, 2014 Nice use of relatively. Well played. 1 Quote Link to comment Share on other sites More sharing options...
Unclejake Posted December 31, 2014 Author Share Posted December 31, 2014 Even only running on 5 cylinders the BA still returned 8.8 litres per 100kms on the way to the BoI. It's pretty much the perfect car 1 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted December 31, 2014 Share Posted December 31, 2014 Have you considered a VY Commodore? 1 Quote Link to comment Share on other sites More sharing options...
