matred Posted December 19, 2014 Share Posted December 19, 2014 What stud are vk commodores. I'm thinking of buying one without wheels and I've just got some 5x120 steel rims to put on. I've read somewhere that 4 cylinder vk's are different than a 6 cylinder. Quote Link to comment Share on other sites More sharing options...
CUL8R Posted December 19, 2014 Share Posted December 19, 2014 4 cylinder is 5/108 - shared with Torana's, HT-K-G Holdens (some Saab/Volvo's also) - Pretty much sfa aftermarket options. 6 cyl and V8 are 5/120. Not to be confused with 5/120.65 - Which is actually Chev (HQ-HZ/WB Holden) 5/4.75" Chris. 2 Quote Link to comment Share on other sites More sharing options...
matred Posted December 19, 2014 Author Share Posted December 19, 2014 How is it measured, do you measure from middle of stud to the one opposite. My ones are close to 108mm across them like that. Quote Link to comment Share on other sites More sharing options...
spiderwebfx Posted December 19, 2014 Share Posted December 19, 2014 No. It's measured as PCD. It's the distance from the center of one hole, to the direct opposite side of the circle (half way between the two opposite studs). If you've measured 108 from stud to opposite stud, it's most likely 5x120. Edit/ this give a rough guideline to get the PCD with two adjacent studs: http://www.wheelfitment.eu/what-is-the-PCD/ Quote Link to comment Share on other sites More sharing options...
Raizer Posted December 19, 2014 Share Posted December 19, 2014 Apparently measuring like this gets you pretty close Quote Link to comment Share on other sites More sharing options...
matred Posted December 19, 2014 Author Share Posted December 19, 2014 Yea I measured it like that and they are 5/120. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted December 19, 2014 Share Posted December 19, 2014 As Chris said, the four cylinder VK Commodores share their PCD with the pre-HQ Holdens, that's 4.25" (or 107.95 in millimetres) The six and eight Cylinder VKs have a 5x120mm stud pattern. Holden used the 5x120mm stud pattern for all Commodores. Pre-VE wheels will bolt on directly to any pre-VE Commodore , VE wheels will need the centre bore machined by 2mm from memory. Quote Link to comment Share on other sites More sharing options...
matred Posted December 19, 2014 Author Share Posted December 19, 2014 So wheels of a hq are 5/108? Quote Link to comment Share on other sites More sharing options...
matred Posted December 19, 2014 Author Share Posted December 19, 2014 Don't worry just seen you said pre hq. Quote Link to comment Share on other sites More sharing options...
