Slacker_Sam. Posted July 10, 2014 Share Posted July 10, 2014 I just passed a wof today & on my way back from the wof place my old volvo coughed a couple of times and died. Its got the B200 MPFI motor. I have checked all the fuses & the fuel pump is working. There is no spark at the plugs or directly from the coil. It runs an optical sensor from the flywheel directly to the Renix ignition module/coil unit. Anyone have any ideas? Cheers Quote Link to comment Share on other sites More sharing options...
77magnum13hundy Posted July 10, 2014 Share Posted July 10, 2014 Test coil and power to coil got a voltmeter or test light? If it has power to coil then trigger would be next piece to check. Quote Link to comment Share on other sites More sharing options...
bigmatt4 Posted July 10, 2014 Share Posted July 10, 2014 check also cam angle sensor just done one last week for a customer just run a meter over it and check it is not open circut Quote Link to comment Share on other sites More sharing options...
Slacker_Sam. Posted July 11, 2014 Author Share Posted July 11, 2014 Yeah. Next port of call is check power feed at the renix unit. If there is power I'll check the crank angle sensor for corrosion on the pick up. I don't think its got a cam angle sensor. Hopefully its just a corroded connection from sitting in the garden for a year. Quote Link to comment Share on other sites More sharing options...
durty Posted July 11, 2014 Share Posted July 11, 2014 Mine did this, then it worked again /ling 1 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted July 11, 2014 Share Posted July 11, 2014 Renix module= fail city. Mum's volvo has been through two of them. Somewhere at 360mania(?) is a pom who thinks renix are good has a flowchart for testing them. Everyone else knows they suck. Quote Link to comment Share on other sites More sharing options...
