77magnum13hundy Posted August 14, 2013 Posted August 14, 2013 what kind of adapter you need? is it the square one into a round one with keyway type deal? re. gbox Quote
flyingbrick Posted August 14, 2013 Posted August 14, 2013 Welcome! I didn't click until you mentioned the wheels. It looks awesome man! What was up with the bonnet? Engine fire? Quote
michaelme Posted August 14, 2013 Author Posted August 14, 2013 what kind of adapter you need? is it the square one into a round one with keyway type deal? re. gbox Yeah that's the one, can't remember which way around it needs now, but it's to connect the Chevette cable to the Gemini/Piazza gearbox Quote
michaelme Posted August 14, 2013 Author Posted August 14, 2013 Welcome! I didn't click until you mentioned the wheels. It looks awesome man! What was up with the bonnet? Engine fire? Heya, yeah cheers again for those! Looks and handles so much better with them No fire that I know of, he was going for a rat-rod look. Quote
EFI_LC Posted August 19, 2013 Posted August 19, 2013 Looking good mate, I need to kick my project back in the guts again. Quote
77magnum13hundy Posted August 19, 2013 Posted August 19, 2013 Yeah that's the one, can't remember which way around it needs now, but it's to connect the Chevette cable to the Gemini/Piazza gearbox Not sure if this helps but fwd corollas have a peice that is about 400mm long that screws the older end into the top and the other has the newer round-bit-with-the-keyway... anyways its the bit on the left in the pic 1 Quote
michaelme Posted August 19, 2013 Author Posted August 19, 2013 Not sure if this helps but fwd corollas have a peice that is about 400mm long that screws the older end into the top and the other has the newer round-bit-with-the-keyway... anyways its the bit on the left in the pic Nice! That might just do it. Can you see the part number on the label? Goes blurry when I try to zoom in on it Quote
77magnum13hundy Posted August 19, 2013 Posted August 19, 2013 na, are you near a picka part? old late 80's manual fwd rollas will have them... i got one in my shed for the viva - toyota box... but i know they just screw in... maybe ring up a 'local dealership' to get the parts number... Quote
michaelme Posted August 19, 2013 Author Posted August 19, 2013 na, are you near a picka part? old late 80's manual fwd rollas will have them... i got one in my shed for the viva - toyota box... but i know they just screw in... maybe ring up a 'local dealership' to get the parts number... Cool, I'll give Toyota a bell. Thanks for the help Quote
michaelme Posted September 23, 2013 Author Posted September 23, 2013 Not sure if this helps but fwd corollas have a peice that is about 400mm long that screws the older end into the top and the other has the newer round-bit-with-the-keyway... anyways its the bit on the left in the pic Success! I can now roughly gauge how fast I'm driving without the aid of a GPS Cheers for the tip! Still a couple available at Pickapart Rosebank Rd if anyone is looking for one 1 Quote
michaelme Posted September 23, 2013 Author Posted September 23, 2013 bought some Pontiac Fiero front calipers off flyingbrick over the weekend. I'll get some photos up, and try get them on the car in the next month or so. Quote
michaelme Posted September 23, 2013 Author Posted September 23, 2013 there's a guy on TradeMe with a complete rear diff/axles/disc brakes from a Piazza. Has anyone done this conversion before? What else would be needed? The chevette currently has a gemini diff fitted with drums Quote
flyingbrick Posted September 23, 2013 Posted September 23, 2013 I suggest opening them up and checking seals and bores mate Quote
michaelme Posted September 23, 2013 Author Posted September 23, 2013 I suggest opening them up and checking seals and bores mate Yeah I'll replace everything I can so they are as "new" as possible Quote
flyingbrick Posted September 23, 2013 Posted September 23, 2013 Sweet Post piston size once you get it open too Quote
CUL8R Posted December 15, 2013 Posted December 15, 2013 Nice work man, looking pretty good, just slowly ironing all the glitches out! g200z should go pretty well, what'd you manage down the 1/4? Quote
michaelme Posted December 15, 2013 Author Posted December 15, 2013 Only had 2 runs before the heater hose burst and spoiled the fun, so the best I ran was 18.43 @ 116.5kms, but I'm sure it has more in it. Looking forward to the next drag day! Quote
michaelme Posted December 17, 2013 Author Posted December 17, 2013 Sweet Post piston size once you get it open too Piston size is 49mm Quote
flyingbrick Posted December 17, 2013 Posted December 17, 2013 Oh right. Yeah 1mm larger than gemini. Quote
