ANT Posted July 30, 2013 Share Posted July 30, 2013 Searched and found no conclusive answer.I have found someone that has made a full 1g turbo manifold for cheap and is willing to do another for me. But the one he made was for a 1gge head. And mine is a 1ggte head. So my question is can he use a exhaust flange made for a 1gge on a 1ggte or are the heads different on 1gge and 1ggte's? I know the best person to ask would be nigel(lofreq) but he hasnt been active for a month. someone want to txt him for me? Quote Link to comment Share on other sites More sharing options...
Hachi-ichi Posted July 30, 2013 Share Posted July 30, 2013 Isn't Chuffanelious using a GE head on a turbo block? As far as im aware GTE runs Siamese ports (3 groups of 2) and so does the GE. Seriously doubt Toyota would have the cheek to make them different. http://www.toyodiy.com/parts/p_J_1985_TOYOTA_MARK+2_GX71-XTMZZ_1104.html GTEU http://www.toyodiy.com/parts/p_J_198810_TOYOTA_MARK+2_GX81-AEPQF_1104.html GE Quote Link to comment Share on other sites More sharing options...
Hachi-ichi Posted July 30, 2013 Share Posted July 30, 2013 part numbers ~ Quote Link to comment Share on other sites More sharing options...
ANT Posted July 30, 2013 Author Share Posted July 30, 2013 So part numbers are the same? Nigel(lofreq) ran a ge head on his turbo block but what i want to know is if a gte exhaust manifold will mount to a ge head and vice versa Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 30, 2013 Share Posted July 30, 2013 Exh. gasket comparo would tell you? Quote Link to comment Share on other sites More sharing options...
Hachi-ichi Posted July 30, 2013 Share Posted July 30, 2013 http://www.ggtmagic.com/laboratory/12exmani.shtm Last sentence of that article says that port shape changes with generation. I didn't know that. GEU GTEU GTEU ports look much wider apart. Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 30, 2013 Share Posted July 30, 2013 ^ Potentially just an optical illusion due to head design. Quote Link to comment Share on other sites More sharing options...
J-Calico Posted July 30, 2013 Share Posted July 30, 2013 ToyoDIY the parts no.s? Quote Link to comment Share on other sites More sharing options...
ANT Posted July 30, 2013 Author Share Posted July 30, 2013 Exh. gasket comparo would tell you?true. May make a trip to Toyota tomorrow.Edit: can someone have a gander online. Its hard on a phone :/ Quote Link to comment Share on other sites More sharing options...
Hachi-ichi Posted July 30, 2013 Share Posted July 30, 2013 ToyoDIY the parts no.s? Did that, they are different. All that means though is that the Head in general is different, not the port placement unfortunately. Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted July 30, 2013 Share Posted July 30, 2013 Different part numbers broseph, I think the turbo has smaller ports, but I'm 90% sure the bolt spacing is the same so they may still work. GZE also has different part numbers but I'm sure they can use GE gaskets. My memory is bad haha. Good luck with your trip to Toyota, I hope your local branch has some clue, my local is useless for this shit. Take a chassis code with you Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted July 30, 2013 Share Posted July 30, 2013 They couldn't even find GZE/or the correct Crown on their system lols, so I told them to look for "turbo Supra xxxx year" but didn't bother getting gaskets through them cause they wanted 160 bucks from Japan. Made my own with proper ex gasket material and hole punches, hah. Quote Link to comment Share on other sites More sharing options...
ANT Posted July 30, 2013 Author Share Posted July 30, 2013 Fuck. Quote Link to comment Share on other sites More sharing options...
ANT Posted July 30, 2013 Author Share Posted July 30, 2013 Maybe ill have to take the exhaust manifold and get a flange cut out for this guy then Quote Link to comment Share on other sites More sharing options...
mjrstar Posted July 30, 2013 Share Posted July 30, 2013 Flanges are the same ... main differences are no oil feeds at the back of the head and different bolt sizes for thermostat housing. More details in my starlet build thread. Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 31, 2013 Share Posted July 31, 2013 mjrstar has the skinny on this. I have stuffed around with them in the past and can say for sure the castings so ports etc are the same. What changes is the what happens after that. Holes/threads are machined to diferent sizes and positions depending on exact model it comes from. If you are willing to get the odd hole machined, taped, helicoiled, sleeved etc they will all work on each other. The valves, springs, col-lets and retainers could be quite different as well especially between the NA and forced versions and generations as well. Quote Link to comment Share on other sites More sharing options...
Chuffaneilious Posted July 31, 2013 Share Posted July 31, 2013 Seeing as im the one sorting out the turbo manifold i can answar your question. It fits on both 1gge and 1ggte heads. 1 Quote Link to comment Share on other sites More sharing options...
