coldturkey Posted June 9, 2013 Share Posted June 9, 2013 So after harping on about how well it starts on the single carb, the L26 wont start. Fuel is being pumped to the carb I can see the right amount fuel in the window There is spark It fires when I spray ether in the carb It seems the carb is just not delivering the fuel? Anything easy I can do like try blow down the fuel line with compressed air? Cant be fucked pulling down the carb. The last time I had it running was saturday last week (just over a week ago) Cheers Quote Link to comment Share on other sites More sharing options...
Escorto. Posted June 9, 2013 Share Posted June 9, 2013 Does fuel squirt out the accel pump jet when you move the throttle? Mine had a bit of gunk stuck under the jet. Quote Link to comment Share on other sites More sharing options...
coldturkey Posted June 9, 2013 Author Share Posted June 9, 2013 Nope it doesnt, well I cant try it while the car is cranking cause im the only one home, but it should still squirt some gas if its there even when not cranking right? Edit, so what can I do to check if theres shit under there? Sorry if it sounds like a newb question, i've rebuilt carbs before but all I care about is that it goes back in the same order, not what each part does Quote Link to comment Share on other sites More sharing options...
Rookie Posted June 9, 2013 Share Posted June 9, 2013 Pull the carb apart and clean the jets, report back after you have done it. Chances are you has diagnosed it correctly. Quote Link to comment Share on other sites More sharing options...
coldturkey Posted June 10, 2013 Author Share Posted June 10, 2013 I pulled it off and managed to get carb cleaner squirting through where I think it should. But put it back on and no luck. If I unscrew the main jet and fill it with crc, it ends up squirting into the barrel. Then it starts briefly but then dies (probably just burning off what was in the main jet chamber). So the fuel isnt getting to the main jet? Also, if I pump the accelerattor pump up and down, should it be squirting fuel into the barrel? cause its not Quote Link to comment Share on other sites More sharing options...
Rookie Posted June 10, 2013 Share Posted June 10, 2013 Probably not, a lot of carbs don't have a pump jet. Did you actually clean the jet? Quote Link to comment Share on other sites More sharing options...
rotorhoe Posted June 10, 2013 Share Posted June 10, 2013 Agree with cleaning jets, also check the floats and finally (just because this is from personal experience) make sure a nut/bolt/whatever hasn't just fallen off somewhere. Trust me, it can be something that simple that messes the whole system up. Quote Link to comment Share on other sites More sharing options...
Steelies Posted June 10, 2013 Share Posted June 10, 2013 is this on the wag with SUs? Quote Link to comment Share on other sites More sharing options...
Rookie Posted June 10, 2013 Share Posted June 10, 2013 A new light is shed. If so, abandon all ye hope captain, no one can help you. 2 Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted June 10, 2013 Share Posted June 10, 2013 Nah, had twin SU's but swap back to factory carb. I thought factory crab had accel pump on these? Quote Link to comment Share on other sites More sharing options...
Rookie Posted June 10, 2013 Share Posted June 10, 2013 Even if it did then it wouldn't stop it running/starting. That's a good point, did you look at the idle jet of just the main? Quote Link to comment Share on other sites More sharing options...
KIRK Posted June 10, 2013 Share Posted June 10, 2013 you need to find a small Bangladeshi child to live in the engine bay and pour petrol down the carb. theres prob heaps looking for work now that they use robots for camel jockeys 1 Quote Link to comment Share on other sites More sharing options...
coldturkey Posted June 10, 2013 Author Share Posted June 10, 2013 lol.... Fortunately there is now one less carb newb in the world. What I was cleaning out were infact the "slow" jets. Once I had a look at my rebuild diagram I found the main jets, and one of them had a tiny bit of white crap blocking the hole..... doh.. First post pretty much solved it. I will now surrender myself to the block for a well deserved ass reaming from everyone. Cheers folks. Quote Link to comment Share on other sites More sharing options...
