e30-323ti Posted May 27, 2013 Share Posted May 27, 2013 I personally don't know of anyone killing 1.............it is possible so ill find out for you ......at a later date. I do, in a baby'd 320i even. The centre looked like it had exploded, and he was just pulling away from a ped. X-ing. Conversely 'built' small cases have been used in 300whp NA screamers in the US, albeit in a 900kg E30 I would count on having a spare handy... Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted May 27, 2013 Author Share Posted May 27, 2013 all the diffs I get will be getting welded so joe dosnt have to weld my mum. and ill get a lsd when I have 1 million $ to get 1 Quote Link to comment Share on other sites More sharing options...
kpr Posted May 27, 2013 Share Posted May 27, 2013 sounds like you're eliminating the weak point with all that welding. spider gears in my beater looked like they were about to give up also, before the mig fixed the issue Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted May 28, 2013 Share Posted May 28, 2013 in my comment i was not taking into account the fact that anybody ever considered running an open diff in a bmw. that's just plain stupid weld it and yee shall have no problems Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 2, 2013 Author Share Posted June 2, 2013 ok for the person that text me sorry I deleted it before I saved your number. this is what the complete front is made up of and yes its all just bolted together. e30 cross member e30 20mm sway bar with new bushes and rod ends. e36 hubs ,discs and callipers with braded lines e36 coil overs 99 m3 control arms tree house racing control bush e30 SPC camber plates e36 GSR stud converstion kit. 1 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 3, 2013 Author Share Posted June 3, 2013 found a radiator the size I needed made a shroud for it and got it all mounted (will cut holes for fans when I have the fans I want) also made templates for flowing air to radiator (will cut out of alloy this week at work. (some pics for the pic whores) that is all Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 4, 2013 Author Share Posted June 4, 2013 bought the alloy home and made it after work 1 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 12, 2013 Author Share Posted June 12, 2013 air box made Quote Link to comment Share on other sites More sharing options...
e30-323ti Posted June 14, 2013 Share Posted June 14, 2013 Liking the alloy work for the radiator inlet, looking forward to get stuck into mine before too long. Re: Your Camber plates. Those look to have a huge 'stack height' If you're needing to get the car lower, and still have suspension (bump) travel, have a look at the GC or Vorshlag plates. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 14, 2013 Share Posted June 14, 2013 / Extend your turrets Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 14, 2013 Author Share Posted June 14, 2013 Liking the alloy work for the radiator inlet, looking forward to get stuck into mine before too long. Re: Your Camber plates. Those look to have a huge 'stack height' If you're needing to get the car lower, and still have suspension (bump) travel, have a look at the GC or Vorshlag plates. no its all good mate in the pic below .that's about ride hight and that's with the e36 front lip being 15mm higher then the e30 lip it can still go 55mm lower with the coil overs . Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 15, 2013 Author Share Posted June 15, 2013 so I bought a box of 1uz headers and header parts of trade me as a set of the manifolds looked like they may work. and yes a set did work perfectly the passenger side is perfect . the drivers side not so much ..as the steering knuckle is right by the last exhaust port so I welded some metal to the flang where I wanted it and cut the bit out that's in the way then just cut some of the other up till it worked.... and ill weld it up fully at work next week will do the job till I make some coustom ones down the line(when it gets a link ecu and turboed/supercharged lol) Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 15, 2013 Author Share Posted June 15, 2013 so Ive been doing a lot of research and thinking about fuel cell vs factory fuel tank.for those that don't know the e30 fuel tank sits under the rear set in front of the rear sub frameand has 2 tanks one on each side.this helps with the sweet handling that the e30s have and it doesn't change the handling characteristics when the tank is getting empty.now I really wanted to use a fuel cell in the boot but from what ive seen and been told (by lots of people that race e30shere in the states and the uk) that the handling is very good with about 30l of fuel but once it starts to get low the handling can change lots and become a bit of a handful.so I have decided to use the factory e30 tank from the parts car and a surge tank in the engine bay.will save me some money to as its a fuel injected model so it has a lift pump to pump to the surge tankand I can also use the fuel lines from the parts car as well. that is all 1 Quote Link to comment Share on other sites More sharing options...
Truenotch Posted June 15, 2013 Share Posted June 15, 2013 You'll save heaps of weight with a fuel cell. Would it fit in the rear passengers side seat area? That's a common choice for maintaining good balance. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 15, 2013 Author Share Posted June 15, 2013 did think about that mate but still want to be able to have 2 seats. I also thought about mounting it in the rear seat area but the factory one sits lower to the ground. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 15, 2013 Author Share Posted June 15, 2013 I for got to say the factory tank is only 9kgs with all fittings. but the main thing is its in the perfect place and wont cost me anything to get the fuel side of things done.(well aprt from sorting out how to get fuel in as the fuel flap hole has been wielded over haha) Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 15, 2013 Author Share Posted June 15, 2013 I found a video of a 1uz e30 at ruapuna some year back http://www.youtube.com/watch?v=Ad79wsLdle4 from what I can tell by doing some sniffing around is its standard motor and full weight car. holy shit im excited now Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 15, 2013 Author Share Posted June 15, 2013 and another http://www.youtube.com/watch?v=K-AX5SzSLnk Quote Link to comment Share on other sites More sharing options...
e30-323ti Posted June 16, 2013 Share Posted June 16, 2013 no its all good mate in the pic below .that's about ride hight and that's with the e36 front lip being 15mm higher then the e30 lip it can still go 55mm lower with the coil overs Don't confuse being able to 'slam your ride' with actually having the bump travel needed for it to be usable. esp. since you are running keeper (or may be tenders) springs upfront says to me you have a lot of droop travel, but probably limited bump (combined with E36 struts being taller than the original E30's). By running less stack height (or raised turrets), you can filp that situation around, as E30/36/46 strut front ends need big roll bars which defeat need for a lot of front droop, just have a look at race car pics, most will have the inside front tyre barely on the ground. Just my 2c from experience, sure you'll figure out what works once you get some testing time on the track. Keep the updates coming. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 16, 2013 Author Share Posted June 16, 2013 Don't confuse being able to 'slam your ride' with actually having the bump travel needed for it to be usable. esp. since you are running keeper (or may be tenders) springs upfront says to me you have a lot of droop travel, but probably limited bump (combined with E36 struts being taller than the original E30's). By running less stack height (or raised turrets), you can filp that situation around, as E30/36/46 strut front ends need big roll bars which defeat need for a lot of front droop, just have a look at race car pics, most will have the inside front tyre barely on the ground. Just my 2c from experience, sure you'll figure out what works once you get some testing time on the track. Keep the updates coming. cheers for that and I fully understand what your saying . and like you say I will get it all sorted with some seat time. for now I just want to get it on the track and go from there. Quote Link to comment Share on other sites More sharing options...
