NicT Posted October 31, 2012 Share Posted October 31, 2012 I thought id put up a project thread of a car i have been working on for the last couple of months. This came to me with a possible electrical fault (misfiring under load) upon further investigation one of the ball bearings that sits in the oil galleries in the head had come out and the head was recieving no oil pressure. This caused the valves to bind on the guides and pushed 2 of them into the combustion chamber. This has lead to a full blacktop 20v rebuild and conversion. It is a factory Blacktop with Silvertop rods, all weighed, crack tested and balanced. All new parts were used and i have been very meticulious with this build taking longer then it should but i believe the end result will be worth it. Out of all the things i own, i do not own a printer!!! 1 Quote Link to comment Share on other sites More sharing options...
NicT Posted October 31, 2012 Author Share Posted October 31, 2012 Somethings to note about the build: - Bought the last 2 valve collets in NZ as the head washer ate them - Bought the last under valve shim in NZ, again parts washer ate it - 2 Valve shims cost your left nut and took a long time to sort out due to under bucket shims. Need to measure this with a spring needle DTI and a very flat surface. You cannot use a micrometer and dont let anyone tell you otherwise even if they do work for toyota - Blacktop looms suck as they have intergrated EVERYTHING through the one loom, and the firewall gromet is resoned together so u cant pull the individual wires through - Working on such a well panelled car, buying $2.99 towels from the warehouse is a sound investment - Altho you can run a heater with a 20v, i wouldnt recomend it as the outlet is incredibly close to the dizzy cover (we used a blank off/relocator kit) - Engine mount needs to be modified - Blacktop 20v you can not run the rwd alternator bracket as the hydrolic tensioner fowels on it - Blacktop 20v Alternator bracket needs to be modified to clear the engine mount - Blacktop Starter motor is completely different to the RWD 16v one, you will need to use 16v Starter Not many issues for a conversion to be honest. We used the SQ engineering dizzy and water relocation kits. Expensive but the choice was made to get something industry proven. Quote Link to comment Share on other sites More sharing options...
ryanfels Posted October 31, 2012 Share Posted October 31, 2012 Strange, i didnt have to modify my engine mounts and im using ae86 ones. I also got away with using a fwd 16v alternator bracket which means i didnt have to modify anything. Quote Link to comment Share on other sites More sharing options...
NicT Posted November 1, 2012 Author Share Posted November 1, 2012 Really? Theres a large casting lump in the way of the drivers side mount, also a dowel pin needs to be removed from it. The engine mount wouldnt bolt up flush unless i skimmed it down. And we didnt have any other alternator bracket, just rwd or 20v blacktop. Blacktop has an intrusive part that hits the engine mount. Quote Link to comment Share on other sites More sharing options...
ryanfels Posted November 1, 2012 Share Posted November 1, 2012 I am using a silvertop bottom end but i didnt think it would be any different. Seems they are though. Yea the silvertop alternator bracket is the same thats why i got hold of a 16v one. I dont have a hydro tensioner to get in the way either as the silvertops are spring loaded Quote Link to comment Share on other sites More sharing options...
QCADTA Posted November 5, 2012 Share Posted November 5, 2012 nice engine build, how much was the sq water kit? seems a shame to do a nice job then have the dizzy stickin out the front, why not run the honda da17 cop's? For a thermostat i was lookin at runin a bmw remote one, think theyre arouns 71deg so about the same as a trd one. Quote Link to comment Share on other sites More sharing options...
NicT Posted November 6, 2012 Author Share Posted November 6, 2012 nice engine build, how much was the sq water kit? seems a shame to do a nice job then have the dizzy stickin out the front, why not run the honda da17 cop's? For a thermostat i was lookin at runin a bmw remote one, think theyre arouns 71deg so about the same as a trd one. Common one to use is the AE92 thermo housing. No idea what the SQ kit cost as martyn sourced it and handed it to me. I think the dizzy out the front looks rad, but thats just me. The COPs would mean going to aftermarket ecu. I know there is examples and what not on the internet about running COPs on the factory coil trigger so they all fire at the same time every time, but who knows how reliable that will end up being? Quote Link to comment Share on other sites More sharing options...
fryup Posted November 6, 2012 Share Posted November 6, 2012 Dizzy looks sweet imo Quote Link to comment Share on other sites More sharing options...
NicT Posted January 23, 2013 Author Share Posted January 23, 2013 This now runs! Will get outside pictures soon. Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted January 23, 2013 Share Posted January 23, 2013 I r excited. 1 Quote Link to comment Share on other sites More sharing options...
NicT Posted June 3, 2013 Author Share Posted June 3, 2013 Weather was nice this weekend, so i went for a drive. Â Â Â Â 4 Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted June 3, 2013 Share Posted June 3, 2013 So sweet. I like those SQ bits, almost makes me entertain the thought of a 20V conversion Quote Link to comment Share on other sites More sharing options...
NicT Posted June 3, 2013 Author Share Posted June 3, 2013 If i was to 20v something again, id buy SQ's whole kit. No hassles, no fears and it all just works. Got a problem, and hes right there to help (not that i had an issues). Quote Link to comment Share on other sites More sharing options...
Hachi-ichi Posted June 3, 2013 Share Posted June 3, 2013 i frequently drive down that road, obviously with horrible timing as i never see the 86. Nice Quote Link to comment Share on other sites More sharing options...
NicT Posted June 4, 2013 Author Share Posted June 4, 2013 You must see my chaser and crown parked out the front regularly tho? Â 86 only had its first outing this weekend gone Quote Link to comment Share on other sites More sharing options...
J-Calico Posted June 4, 2013 Share Posted June 4, 2013 Wow, This is very cool. Great work, also agree the dizzy looks tough. Quote Link to comment Share on other sites More sharing options...
Sammy Posted June 4, 2013 Share Posted June 4, 2013 Simply gorgeous car sir used too follow one of your old threads on garagedori 1 Quote Link to comment Share on other sites More sharing options...
Hachi-ichi Posted June 4, 2013 Share Posted June 4, 2013 See the gold X90 MARK II all the time, used to see the crown, haven't in a while. and a random EXIV sometimes Quote Link to comment Share on other sites More sharing options...
NicT Posted June 6, 2013 Author Share Posted June 6, 2013 Yea the crowns in the garage, has some overheating issues atm. Need the 86 gone so i can have a poke around the crown. Think its BHG Quote Link to comment Share on other sites More sharing options...
Hachi-ichi Posted June 6, 2013 Share Posted June 6, 2013 going 1J turbo with it? Quote Link to comment Share on other sites More sharing options...
