Yowzer Posted October 12, 2012 Author Share Posted October 12, 2012 Don't worry, appears to be M12x1.5. Which poses a bit of a problem as all these things are 1/8npt. Which ain't gon' work Quote Link to comment Share on other sites More sharing options...
mark105 Posted October 13, 2012 Share Posted October 13, 2012 just drill and tap it like i did. they are only alloy so piss easy to do. i had one of those originally before i got a factory thermo housing of ky with the right holes in it. also they are useless for anything but thermo fan switches i found as you cant get a temp sensor in one close enough to the block for it to warm up with the engine so you can use it as the ecu temp. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted October 13, 2012 Author Share Posted October 13, 2012 Yeah it's only gonna be used for fan control. I figured for ECU signal it'd need to be on the block side of the thermostat. Quote Link to comment Share on other sites More sharing options...
