NVIOUS Posted May 29, 2012 Share Posted May 29, 2012 Hey i was wondering what youd have to change/do to make the starion front adjusties fit the front of an ex? Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted May 29, 2012 Share Posted May 29, 2012 EX top hat on Starion struts. Starion steering knuckle on EX ball joint. (or complete Starion arm) Quote Link to comment Share on other sites More sharing options...
Southerner Posted May 29, 2012 Share Posted May 29, 2012 Yea the easiest way as Damien! said is Ex lancer top hats on starion struts. You can use starion control arms aswell as the knuckles for more length(worked out to give me negative camber in my car). If you shorten the struts you can use KYB inserts out of a celica to give you more travel. Then just put a threaded sleeve over the top. Check out my project thread on how i had mine setup. I pretty much followed Seedy Al's guide on how to do the struts http://www.oldschool.co.nz/phpbb/viewtopic.php?f=48&t=26443 Or just use the search function to find more info Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted May 29, 2012 Share Posted May 29, 2012 Fuck I'm glad that thread is getting used. Quote Link to comment Share on other sites More sharing options...
NVIOUS Posted May 30, 2012 Author Share Posted May 30, 2012 Southerner do you mean shorten the original lancer shocks? Thanks for your guys help Quote Link to comment Share on other sites More sharing options...
Southerner Posted May 31, 2012 Share Posted May 31, 2012 Southerner do you mean shorten the original lancer shocks?Thanks for your guys help Just shortened the strut tubes, then put in shorter shocks out of a celica. Quote Link to comment Share on other sites More sharing options...
Ogre Posted June 1, 2012 Share Posted June 1, 2012 Starion struts made into coilovers with bilstien shocks.Using starion control arms, steering knuckle and tie rod adjusters in an LA lancer (not really any different than an EX tho).I would suggest using starion as opposed to the EX or sigma struts as they use the smaller stub axle and hubs and have shit all brake upgradability. One issue im constantly having is the top hat rubbers only lasting about a year because of the increased stiffness of the shocks, even when using brand new tophats. ive ended up fully welding some up, but really need adjustable pillow mounts or somthing. Quote Link to comment Share on other sites More sharing options...
