morkster Posted May 3, 2012 Share Posted May 3, 2012 I think it's best to pack the hub with some grease too ay. Quote Link to comment Share on other sites More sharing options...
felixx Posted May 3, 2012 Author Share Posted May 3, 2012 hub had heaps of grease in it, I scooped it all out and replaced with shiny new stuff, The original stuff looked nice n clean, but I brought a big thing of grease so splashed out. Old grease got put in a rubber glove and put in my log burner Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted May 6, 2012 Share Posted May 6, 2012 I used the tapping on my hand method.. took about 5- 8 minutes. that's usually the meathod we all use. But 5-8 mins? Wow. Your were concentrating to much on the bwebs and not enough on the job at hand.... Oh and don't get too much grease on your shaft. Quote Link to comment Share on other sites More sharing options...
mjrstar Posted May 6, 2012 Share Posted May 6, 2012 I use a slightly different method (I learnt working on aircraft when doing 20-30 a day) which involved using a piece of nylon / plastic chopping board, putting a dollop of grease on the board then dragging just one side of the outer inner taper race through the edge of the grease,(it uses the height difference between the inner and outer cage to graw in the grease) it was a really clean method and you could tell when you had a good amount of grease coming out between the top (outer end ) of the rollers. -bloody hard to explain/ probably makes no sense but I have not used a normal hand application method since.. I might need to whip out MS paint to explain fully.. Quote Link to comment Share on other sites More sharing options...
Stu Posted May 8, 2012 Share Posted May 8, 2012 I might need to whip out MS paint to explain fully.. I understand your technique but require MS paint diagram anyway for lolz please Quote Link to comment Share on other sites More sharing options...
