BIG A Posted March 7, 2012 Share Posted March 7, 2012 I need some help in trying to find a electronic ignition kit for my L20 engine does anyone know of someone who has done this before or may know of someone who is a bit of an expert with the L20 engines? I have looked at hotspark but it doesnt really give too much information. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted March 7, 2012 Share Posted March 7, 2012 were you looking for performance or just ease of stz? Not sure If an l28 dissy fits But i have an eletronic one here you can try, and then if you want to go all out for mega spark an MSD or similar setup will be the go. Plus you get sweet rev limit chips so you can drive round all bozuko like hitting rev limit at 3000 rpm CHUR Quote Link to comment Share on other sites More sharing options...
DJZ Posted March 7, 2012 Share Posted March 7, 2012 L28 electronic dizzy would be the easiest swap, there are heaps of write ups on how to do it for 240Z's etc so the info should be pretty easy to find. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted March 7, 2012 Share Posted March 7, 2012 I did exactly all this with an L28 dizzy - chucked in MSD also - set the rev limit to 4000rpm - was LOL Quote Link to comment Share on other sites More sharing options...
Snoozin Posted March 7, 2012 Share Posted March 7, 2012 I'm keen to do this to the Ced at some point too. BE GONE POINTS. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted March 7, 2012 Share Posted March 7, 2012 best you find an S30 dizzy ASAP then.. Biggest hasssle I had was playing with the little adapter plate that attaches to the lock clamp so you can have the vacuum advance in a place that isn't restrictive to adjusting your timing.. I ended up mashing different plates with an adjuster off a Mk1 cortina from memory.. Quote Link to comment Share on other sites More sharing options...
BIG A Posted March 7, 2012 Author Share Posted March 7, 2012 L28 electronic dizzy would be the easiest swap, there are heaps of write ups on how to do it for 240Z's etc so the info should be pretty easy to find. Yeah but will it fit an L20 engine??? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted March 7, 2012 Share Posted March 7, 2012 L20A Yes Quote Link to comment Share on other sites More sharing options...
DJZ Posted March 7, 2012 Share Posted March 7, 2012 Well it would actually fit an L20B, but wouldn't be any use hah! As long as you aren't trying to fit an optical dizzy the only thing you will need to play with is as mentioned above, make sure you get the bottom plate that bolts between the dizzy and timing cover as they are different, I'm 90% sure of that. Quote Link to comment Share on other sites More sharing options...
BIG A Posted March 8, 2012 Author Share Posted March 8, 2012 Yeah Im pretty sure mine is an L20A so yay thanks for the help guys I will now try and track a dizzy down. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted March 8, 2012 Share Posted March 8, 2012 Pretty hard to mix them up but very undesirable results if you do... FYI A is a 6 cylinder B is a 4 cylinder Quote Link to comment Share on other sites More sharing options...
BIG A Posted March 8, 2012 Author Share Posted March 8, 2012 Yes I already got that as they called it the L20 and then the L20A later in 1969 so not to get confused with the 4 cylinder L20B. Quote Link to comment Share on other sites More sharing options...
