tapping on ohv (push rod motor)
hmmmnz
as kk said, how confident are you of your tappet setting ability? (not saying you are shit...)
on an engine that isn't running i'm
as confident as a mechanic i'd say,
i rebuild bikes in my spare time, so no stranger to doing valve clearances,
as for doing clearances when running, thats something ive never tryed
is easy as, actually easier when its running
ok some more videos with rocker cover off,
fan belt connected, and disconnected.
the noise doesnt seem to be coming from anywhere in perticular, its starting to piss me off :D
fan belt on,
http://youtu.be/Kl7AVLcDxjU
fan belt off
http://youtu.be/MIMgIvF9gwY
fan belt off
http://youtu.be/kcfrf9Pkqh0
fan belt off, push rod cover off
http://youtu.be/MVAoGAbshFk
did the clearences again on the fly, 2nd cylinder tight on exhaust, loose on inlet, 3rd cylinder tight on inlet
5th cylinder loose on exhaust all the rest were preyy good,
going on 0.30mm - 0.35mm
recommended 0.33mm (0.013 inch)
i'll do a compression test when the mrs comes back from her walk :D
If you want to maintain ridgey didgey motor specs - heres a 3.3L car (POS) but the motor was rebuilt and has done fuck all miles since (8000 miles if you subtract the milage on the invoice from the milage on the speedo pic) - although that was 22 years ago..
http://www.trademe.co.nz/motors/used-ca ... 045252.htm
give him a yell - tell him 'es dreamin and offer him a crate of Waikato/Lion Red plus a touch more than scrap value and you'll take it off his hands..
if i do a transfer, it'll be the 3.3 with the 4 speed,
i did look at a small gm v8, but i can't be fuct going through the whole cert bother,
it cost me a small fortune on my van to get done,
(lifted delica on 33" tyres)
i think i'll end up buying this pulling the engine and box with the e-od unit and selling the victor as a roller to some one who wants to do a v8 conversion,
i have seen some wicked v8 victors,
i'll keep my old man spec velox though,
