Copy this man, he seem to know what he's doing, he's on the nissan diesel forum too. 1.7 bar of boost.
Xz8u3_NzX88
This LDs got 2 bar up it.
NLAIosfjAWs
There's no throttle body pritty sure so fuel will do what it needs to?
I can't adjust the fuel pump anyway can't see how/.
Oh yea nissandiesel forum cheers forgot that one. But oldschool.co.nz is always the first resort.
T3 turb sounds good. I'll get one of those - external if I can.
theres a nut with a screw in it on the top of the pump towards the back.put a screwdriver on the screw and crack the nut...
makes sure you know how far you have turned the screw so if it turns to shit you can put it back how it is..
i tuned mine by seeing how much smoke it was making and the colour of the smoke, then back it off a tad..
shes still boosting so mustve worked.
  • 12 years later...
Hay.
Real sorry to drag this old thread up.
But I want to turbo an LD28 that I don't actually have yet ...using parts I do have sitting on the shelf.
I can make a log manifold or just a simple J pipe for the turbo.
My questions are..
Do you think and evo 4 td05hr 16g would do the job. ?
What else dk I need to fuck with to add more fuel.?
And running an EGT gauge a good idea.?
As per normal....thanks for your time
Jesus, that’s a memory from 12 years ago when I was trolling in a blacked out mk2 transit with ld28t haha.
mine had a 280z manifold and turbo irc.
a td05 should be fine , J pipe will get it done.
i don’t think mine had any boost compensator on the pump at all .
just wind and go.
ever gauge will make fuel tuning less of a guess
just wind and go.
Pretty simple then ay
Looked like it.
was a cool little rig, even though it looked sketchy.
had 4 wheel discs, upgraded seats.the auto was epic, it was just fully rolling coal, I turned her down some eventually.
untapped running 13psi
