ex lancer wat! Posted January 26, 2012 Share Posted January 26, 2012 wont leave third gear because i was raceing it so now i need a new box for a g62b motor, what boxs will work Quote Link to comment Share on other sites More sharing options...
ex lancer wat! Posted January 26, 2012 Author Share Posted January 26, 2012 will a sigma or gsl lancer work Quote Link to comment Share on other sites More sharing options...
Ranter Posted January 26, 2012 Share Posted January 26, 2012 Why not repair the one you have? If you keep throwing away repairable gearboxes there will be none left when you really need a replacement. Gonna assume its narrow block so I believe a Sigma one will fit. Quote Link to comment Share on other sites More sharing options...
ex lancer wat! Posted January 26, 2012 Author Share Posted January 26, 2012 yes that is a valid point but what sort of price will i be looking at Quote Link to comment Share on other sites More sharing options...
Mitch.W Posted January 26, 2012 Share Posted January 26, 2012 just had it happen to mine (i was stuck in 4th) i took it apart just to see whats happening and found out its a pritty simple fix and now i know to to take apart gearboxes. Quote Link to comment Share on other sites More sharing options...
ex lancer wat! Posted January 27, 2012 Author Share Posted January 27, 2012 what was wrong with your one. my box is a hydrolic clutch Quote Link to comment Share on other sites More sharing options...
Mitch.W Posted January 27, 2012 Share Posted January 27, 2012 heres the thread on it viewtopic.php?f=1&t=31424 Quote Link to comment Share on other sites More sharing options...
fuel Posted January 27, 2012 Share Posted January 27, 2012 you would want a starion box. Quote Link to comment Share on other sites More sharing options...
ex lancer wat! Posted January 27, 2012 Author Share Posted January 27, 2012 fuel i have done a bit of research and yes you are 100percent corrent! thank you. Quote Link to comment Share on other sites More sharing options...
ex lancer wat! Posted January 28, 2012 Author Share Posted January 28, 2012 turns out all it needed was the the plastic peice that covers the ball on the shifter was an easy fix!!! also drilled out the holes that hold the shifter on to run bigger bolts for more strength aparntly its a common problem to snap these 3bolts on mitzi boxs Quote Link to comment Share on other sites More sharing options...
DiRtYnIgMa Posted January 28, 2012 Share Posted January 28, 2012 i have had 3 gear boxes do that i just took the gear lever out and worked it with a screw driver Quote Link to comment Share on other sites More sharing options...
