kkatl Posted January 20, 2012 Share Posted January 20, 2012 hi all. i went for a drive to town today all is well, until the return trip when an obvious knocking noise starts coming from my engine. i have a 1300 mk2 escort crossflow. i was wondering if anyone could help me out with this problem, i have a feeling its a big end bearing gone but im not entirely sure if it is because ive never had one fail on me before. the knocking only occurs at around 4-5000rpm and i can do about 70km/h before itl start knocking. but i can do 100km/h take my foot off the accelerator and it wont knock. its only when i gas it. any ideas guys? Quote Link to comment Share on other sites More sharing options...
ESKIN8R Posted January 20, 2012 Share Posted January 20, 2012 Hi, Sounds to me not to be your engine at all, If you had a big end knock it would be there all the time. You'd hear it badly if you had it and reved the engine it would have a clattering noise, could be something like a driveshaft universal worn casuing the noise? Or other suspension related noise. Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted January 21, 2012 Share Posted January 21, 2012 If you rev it while the car isnt moving does it make that sound? I had a nasty knock once and thought the same thing. Was a wheel bearing. Quote Link to comment Share on other sites More sharing options...
kkatl Posted January 21, 2012 Author Share Posted January 21, 2012 yip just had another drive around. when revved to 4000rpm at idle. it knocks, ever since the knocking i have noticed significant power loss. Quote Link to comment Share on other sites More sharing options...
Sorensin Posted January 21, 2012 Share Posted January 21, 2012 Do you have a compression tester? I broke a piston once, still ran - had power lose - had knocking noise - pretty sure it always knocked though... Quote Link to comment Share on other sites More sharing options...
ESKIN8R Posted January 21, 2012 Share Posted January 21, 2012 Maybe its a broken engine mount? Check those out Quote Link to comment Share on other sites More sharing options...
sholdowa Posted January 28, 2012 Share Posted January 28, 2012 Had a knocking at over 50mph once. Turned out to be an elastic band stuck in the tyre... Quote Link to comment Share on other sites More sharing options...
QCADTA Posted January 29, 2012 Share Posted January 29, 2012 have you dumped the oil and cut your oil filter open to see whats been floating around in ya oil? Quote Link to comment Share on other sites More sharing options...
danger Posted January 31, 2012 Share Posted January 31, 2012 Get someone to rev it in neutral while you try pinpoint the source of the sound. Try putting a screwdriver or something to your ear and to different parts of the motor kida like a stethoscope. should be able to tell you what piston and give you an idea if its top or bottom end. Quote Link to comment Share on other sites More sharing options...
