W50 into kp61
benjike70
Hi guys contemplating buying a w50 with 4age adapter/custom bellhousing to go behind 4age in my kp61.Can i squeeze one in?without chop chop?had a look on club k and here and found out tunnel needs adapting for the alloy boxes but isnt the w50 steel case box a bit smaller?
I should also add i have a manual body.
thanks.
not the advice you're after. but use a t50, or w55/7/8 if you need something stronger. steal case is quite heavy.
steel case may fit, w55's dont need that much work to fit. but depends where engine is mounted also
Cheers mate,can get the whole set up for less than 300 though still not worth it you reckon?
i'd still go for a t50, if your running a n/a 4age. light weight is your friend will go alot better shaving some kg's plus t50 is a nicer box imo, than all the w boxes. no sloppy w box shifter syndrome
but if your running a turbo 4age. that steel option is looking better, being nice and cheap
