peteretep Posted September 23, 2011 Author Share Posted September 23, 2011 its only a pretend race car really, it drives around on the road alot more than the race track etc Quote Link to comment Share on other sites More sharing options...
Spencer Posted September 23, 2011 Share Posted September 23, 2011 Did scrots have a factroy PCV system chaps? or was it one of those setups that has a controlled air leak into the crank? Just wondering on a stock kent how the breather system was setup? Quote Link to comment Share on other sites More sharing options...
Raizer Posted September 23, 2011 Share Posted September 23, 2011 Yeah they do have a PCV on the block, they also have a vented oil cap. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted September 27, 2011 Share Posted September 27, 2011 Thoughts on diamater of lines? My -12N lines just turned up and they are a bit bigger than what i was expecting, could to large a lines be a problem? 2L engine requires 2L catch tank doesnt it also? Quote Link to comment Share on other sites More sharing options...
Raizer Posted September 27, 2011 Share Posted September 27, 2011 Thoughts on diamater of lines? My -12N lines just turned up and they are a bit bigger than what i was expecting, could to large a lines be a problem? 2L engine requires 2L catch tank doesnt it also? The lines should be fine. 2L engine requires a 1L tank minimum, 2.1+L engines needs 2L tank, personally would aim for at least a 1.5L tank. 5.1 (7) Oil catch tanks: shall be fitted to engines with open circuit crankcase breathingsystems as follows; (a) Engines up to and including 2000cc shall have a minimum of 1 litre catch tank capacity. ( Engines exceeding 2000cc shall have a minimum of 2 litre catch tank capacity. Note: Do not apply equivalence factor multipliers. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted September 27, 2011 Share Posted September 27, 2011 cool cheers bro Will order some alloy lugs to have welded onto cover and should be on track for one less leak Dont buy these VvVvV every join on them leaks Quote Link to comment Share on other sites More sharing options...
peteretep Posted September 27, 2011 Author Share Posted September 27, 2011 I have a -6 (3/8 hose I think) line on my setup as it's the same size hose as original, there's oil in the catch can so it obviously works My new tank will be just below 1.5 litres for my 1800 motor Also, I have not tested the blowby yet as the car hasn't been running due to starter motor, but I will test it in due course Quote Link to comment Share on other sites More sharing options...
Roman Posted September 28, 2011 Share Posted September 28, 2011 What is actually coming out of the catch can, is oily, or more like water vapour? Quote Link to comment Share on other sites More sharing options...
peteretep Posted September 28, 2011 Author Share Posted September 28, 2011 It's mostly emulsified oil I think, but as it drips out over a period of days it's quite to tell as it kind of separates on the floor Quote Link to comment Share on other sites More sharing options...
