lou Posted April 24, 2011 Share Posted April 24, 2011 What front disk setup you going to be using mate? Nice truck too, nice and original looking. Quote Link to comment Share on other sites More sharing options...
kicker Posted April 24, 2011 Author Share Posted April 24, 2011 The setup I have for it came off an '84 B1600, I needed to get the sticky-outtie booster to clear the column shift mechanism. Quote Link to comment Share on other sites More sharing options...
lou Posted April 24, 2011 Share Posted April 24, 2011 oh ok.Was that the year they changed over? Mines been converted to 5 speed floor. Sorry for the stupid questions, This is my first mazda and I've spent the last 10 years on late model cars. Quote Link to comment Share on other sites More sharing options...
kicker Posted April 24, 2011 Author Share Posted April 24, 2011 No worries mate, I'm in the same boat as you. I think there was a change in '81, along with the addition of discs the control arms are a slightly different shape and there were some interior changes too. I think B2000's had front discs all along. Quote Link to comment Share on other sites More sharing options...
lou Posted April 25, 2011 Share Posted April 25, 2011 Have you been to the public library? They usualy have a wide selection of the haynes manuals. My local had the one for ours which I took to with the photocopier for a dozen or so pages. Will look at buying one when I have the spare cash. Quote Link to comment Share on other sites More sharing options...
kicker Posted April 25, 2011 Author Share Posted April 25, 2011 Yeah I had a look in Wellington library but couldn't find one so I bought a chilton manual, let me know if you need any info from it and I'll scan the pages for you. I've got an owners manual too with some extra info and a wiring diagram in it, just have to find it as it seems to have gone walkabout Quote Link to comment Share on other sites More sharing options...
lou Posted April 25, 2011 Share Posted April 25, 2011 Yeah I found an owners manual in the glove box when I bought it. Hopefully I'll buy a haynes of chilton soon though, are a few floating around trademe at the moment. Saw one not sell with a $10 reserve the other day. Asked for it to be offered but he never did. gutted. Quote Link to comment Share on other sites More sharing options...
Sparkle Posted May 11, 2011 Share Posted May 11, 2011 nice man, those steels will look really choice! Just keeping them silver? Quote Link to comment Share on other sites More sharing options...
lou Posted May 11, 2011 Share Posted May 11, 2011 Yeah man. soo slick. Quote Link to comment Share on other sites More sharing options...
kicker Posted May 11, 2011 Author Share Posted May 11, 2011 Cheers guys I haven't thought about what colour they'll be, I'll have to try some photoshop combinations, any suggestions? Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted May 11, 2011 Share Posted May 11, 2011 rather than taking width out of the inside just get them to change the offset slightly more negative. May work out cheaper Quote Link to comment Share on other sites More sharing options...
Jase Posted May 11, 2011 Share Posted May 11, 2011 dear mr kicker, i have the same steels x 4 widened to 10's would you like to take two off my hands in exchange for two of yours and some sort of deal, the tens fit fine on the rear but are a little too wide for the front. hence me searching for a pair to setup for the front. Quote Link to comment Share on other sites More sharing options...
Jase Posted May 11, 2011 Share Posted May 11, 2011 as per on the left, widened by steel surgeon in ak at $65 each Quote Link to comment Share on other sites More sharing options...
kicker Posted May 11, 2011 Author Share Posted May 11, 2011 rather than taking width out of the inside just get them to change the offset slightly more negative. May work out cheaper I could probably gain 10mm-ish negative because of where the band that the centre sits on is taking it down to +28mm, you're right it would be easier, I'll space the fronts out 10mm and see how fitment is then. dear mr kicker,i have the same steels x 4 widened to 10's would you like to take two off my hands in exchange for two of yours and some sort of deal, the tens fit fine on the rear but are a little too wide for the front. hence me searching for a pair to setup for the front. Ooooh just felt a tingle in my pants area I'd be keen to sort something out, how would they fit under the wellside? I got mine off a '05 Holden Colorado, only 16" six stud steels I have been able to find as most seem to have alloys or some kind of 4x4 style Quote Link to comment Share on other sites More sharing options...
Jase Posted May 11, 2011 Share Posted May 11, 2011 will get full offset measurements etc tommorow tbh i had know idea what they were off, should fit with stretch by my measurements unsure of your diff width though, carlos added 3" to the outside of the centre as they're quite offset towards the guts Quote Link to comment Share on other sites More sharing options...
kicker Posted May 11, 2011 Author Share Posted May 11, 2011 Sweet, cheers man. I'll measure up the space in back, would be sweet to get 10's in Quote Link to comment Share on other sites More sharing options...
Jase Posted May 12, 2011 Share Posted May 12, 2011 they're, front 120mm, rear 140mm,10"overall outside to outside but tire mounting is a 9" bead to bead Quote Link to comment Share on other sites More sharing options...
kicker Posted May 13, 2011 Author Share Posted May 13, 2011 I spaced out the front wheels by 10mm to simulate an offset of +28mm, on full lock the rims now clear the upper control arm and sway bar mount by 5mm (at full extension of suspension). Is this enough clearance? Are there any other factors I should consider? A few extra millimetres could probably be gained on top of the 10 but was just being conservative. Had a quick measure up at the back. With +38mm offset (142mm to rear rim edge) and no guard rolling, the outside face of a 9" wheel would stick out about 1/2 an inch from the guard. I may have to pass up your offer though Jase, even though the wheels are similar I think my OCD side may keep nagging away at me about the slight differences between them, sorry dude. Quote Link to comment Share on other sites More sharing options...
Jase Posted May 13, 2011 Share Posted May 13, 2011 all good chap i was aiming for that 1/2" out as tire stretch was going to happen with my wellside setup, wonder what mine are off then? will continue hunting for some fronts/buy two colorado rims for the front. Quote Link to comment Share on other sites More sharing options...
Beaver Posted September 24, 2011 Share Posted September 24, 2011 pretty sure I saw your steels sitting at Howats today when I dropped my wheels off haha Quote Link to comment Share on other sites More sharing options...
