Beaver Posted December 20, 2010 Share Posted December 20, 2010 the water temp gauge and the fuel gauge on the avenger dont go. all the dash lights, high beam indicator, indicators and charge light work, and there is only one big plug that goes into the back of the dash. if i disconnect the water temp sender and earth the wire, the gauge goes to max, which indicates the gauge itself is working (am i right?), so it must be the sender. correct? and correct me if im wrong but the fuel gauge sender thingy varies is resistance depending on the level of fuel? so if i hook up a multimeter to the tank and adjust the level of petrol (or take it out and move it up and down) i should get different resistance readings? in the haynes manual it said if both of these are not working it may be due to a fault with the voltage stabilizer (which it says is plugged into the back of the dash). however mine doesnt have one, or a place for one to be. Quote Link to comment Share on other sites More sharing options...
Hemi Posted December 20, 2010 Share Posted December 20, 2010 yup fuel sender should just be a restive ladder type dealio , and if its flash a seperate clip thing for the empty light . Quote Link to comment Share on other sites More sharing options...
mark105 Posted December 20, 2010 Share Posted December 20, 2010 in the haynes manual it said if both of these are not working it may be due to a fault with the voltage stabilizer (which it says is plugged into the back of the dash). however mine doesnt have one, or a place for one to be. dad said these things always go and it would be where he would look first when i told him your issues the other day. Will hit dad up about speedo cable now, if hes got one bring it over, dad will probably point out the voltage regulator in about 2 secs if its got one. Quote Link to comment Share on other sites More sharing options...
Beaver Posted December 20, 2010 Author Share Posted December 20, 2010 legend, let me know ho you get on, cheers Quote Link to comment Share on other sites More sharing options...
Avenga Posted December 20, 2010 Share Posted December 20, 2010 The voltage regulator is really easy to spot. if you take the cluster out, it is on the back of the cluster sort of just above the speedo cable. its a rectangular box, usually gray. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted December 20, 2010 Share Posted December 20, 2010 Some cars i've had the stabiliser is inside the gauge cluster- have a look. If the car has been sat ages without much fuel in it the variable resistor thing can corrode over. Usually a few good bends sloshing the petrol around and it going up and down can get it working again-in my old triumph i pulled it out of the tank and just very lightly sanded the corrosion off the resistor. Quote Link to comment Share on other sites More sharing options...
mark105 Posted December 20, 2010 Share Posted December 20, 2010 just talked to dad, said the all the dash lights just run of normal 12v but the gauges are all powered by the voltage regulator, so if its not there or dead then its most likely the problem. Quote Link to comment Share on other sites More sharing options...
Beaver Posted December 20, 2010 Author Share Posted December 20, 2010 hmmm i had a dam good look for the voltage stabilizer, pulled the dash apart and everything, couldnt find it. will resume search tomoro Quote Link to comment Share on other sites More sharing options...
mark105 Posted December 20, 2010 Share Posted December 20, 2010 possible its just not there? and hence why yours gauges don't go. Quote Link to comment Share on other sites More sharing options...
Beaver Posted December 20, 2010 Author Share Posted December 20, 2010 yeh completely possible, although I would have thought i would have found some loose wires/empty slots etc? Quote Link to comment Share on other sites More sharing options...
Avenga Posted December 20, 2010 Share Posted December 20, 2010 I looked through my manuals and all but 1 shows the UK super dashboard (it has oil, volts, water, fuel and speed guages in a strip format) which has the voltage regulator on the back of the cluster. so does the round cluster Alpine version. This manual has a photo of the back of the NZ super cluster and you can't see the voltage regulator but looking at the wiring diagram it does have one somewhere. I could email you picture so you can trace the wires back is probably your best bet. I have a double up of this manual. it covers a few things the haynes one doesn't I can give it to you on wednesday if you like. I got it of trademe for $1. Quote Link to comment Share on other sites More sharing options...
Beaver Posted December 20, 2010 Author Share Posted December 20, 2010 that would be great man. the haynes one has an astrix next to it saying "where fitted" so yeh who knows. ill have a chat to marks dad tomoro when i go get the speedo cable and see what he thinks (sounds like hes an expert) Quote Link to comment Share on other sites More sharing options...
