10Speed Posted December 13, 2010 Share Posted December 13, 2010 Actually it's not mine, it's the girlfriends... (but it will be my project) 1997 Vespa Piaggio Ciao 50cc, Single Speed, rigid, rev limit to about 45kph Plans include vintage rego. 75cc Malossi racing kit Dellorto SHA carb Expansion chamber Variator Conversion Re-geared transmission to improve top speed Racing Tires most of the above has been ordered from the states now waiting on delivery... ( http://www.treatland.tv/vespa-piaggio-k ... ts-s/3.htm ) Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 14, 2010 Share Posted December 14, 2010 i truly despise you dear sir Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 14, 2010 Author Share Posted December 14, 2010 mission accomplished then Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 14, 2010 Author Share Posted December 14, 2010 downstairs now, awaiting fitting - apparently circuit pipes are good for torque Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 15, 2010 Author Share Posted December 15, 2010 another parcel arrived this morning: unfortunately the rim is a 16 and I need a 17, but thats easy to solve. However what is good is the variated transmission (and the variator) Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 18, 2010 Author Share Posted December 18, 2010 final package of goodies is here now, just in time for christmas... new (actually second hand, but unused) gears for the hub transmission changes it from a 12:1 to 9:1 reduction, I think. Will fit these once it is all tuned and I am happy with the torque. Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 18, 2010 Author Share Posted December 18, 2010 a front variator - didn't come with alternate weights but meh (for now at least) Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 18, 2010 Author Share Posted December 18, 2010 new dellorto + aircleaner and 20 odd jets so I can get the tune just right. btw if anyone is tuning a dell and wants to try some other sizes let me know Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 18, 2010 Author Share Posted December 18, 2010 moped racing tires, so soft and sticky Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 18, 2010 Author Share Posted December 18, 2010 and the best part, a 75cc cylinder with lots of nice ports Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 20, 2010 Author Share Posted December 20, 2010 started preping the cylinder last night, chamfered the ports and started to set ring end gap. Can't find a measurement online so I figure .15mm will be ok for something this small.. did the first ring no problem, however when popping the second off the piston... )-: popping up to the scoot shop at lunch time fingers crossed... Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 21, 2010 Author Share Posted December 21, 2010 well no joy at the scooter shop, actually the guys at scootling didn't seem to interested at all, probably fair enough since I hadn't brought the kit from them... so another order from the states is on the way: http://www.treatland.tv/malossi-46-5mm- ... 356218.htm and in the mean time will fit the carb and pipe for hopefully a noticeable performance improvement Quote Link to comment Share on other sites More sharing options...
spanners Posted December 21, 2010 Share Posted December 21, 2010 I just gonna ask.... is this shit cheap or is this the worlds most expensive scooter? I 200% appreciate awesomeness, I am just so scared aforementioned mrs will ruin racing tyres etc Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 21, 2010 Author Share Posted December 21, 2010 yes and no, the tires were $24US each which is cheaper than most bicycle tires I own. I enjoy the weirdness of mopeds and theres a certain amount of pleasure in doing 80kph on a vehicle designed to do 40kph Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 22, 2010 Author Share Posted December 22, 2010 took some parts off put some new parts on - pretty easy had to swap the choke mechanism from old carb to new, even though this was meant to be specifically for this bike. And didn't even have to stuff around with the throttle cable (one of my least favorite jobs) just left connected to the old slide and put the whole lot into the new carb took for a blast around Kepa Rd and Tamaki Drive, and am truly impressed with the results. From just a carb & expansion chamber it feels completely different. Top speed has increased from 45kph to 75kph (measured with a gps). Still too slow up hill, but variating should fix that. Haven't checked the jetting yet - hopefully not running to lean. Really looking forward to the 75cc kit and machining the case... should be an awesome bike... Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 28, 2010 Share Posted December 28, 2010 just use 1 ring you pussy ad more power and more wank single ring race piston Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 28, 2010 Author Share Posted December 28, 2010 running a single crossed my mind, but want to ensure I get maximum compression... Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted December 28, 2010 Share Posted December 28, 2010 Frame mods next? would look mean bare metal'd, make it look old. drop down bars? Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 29, 2010 Author Share Posted December 29, 2010 Frame mods next? would look mean bare metal'd, make it look old. drop down bars? sounds like a good plan to me - but the gf might not sign off on it... Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted December 29, 2010 Share Posted December 29, 2010 YEah exactly like that less the gangster writing, something about that seat still doesn't look rite Quote Link to comment Share on other sites More sharing options...
