W50 Starter Motor Options For Pinto 2ltr
Elmo2003
i adapted a big block chev aftermarket gear reduction starter for my pinto. 2.5horse power! worked a treat!
untill the raw power of the starter broke its own mounts.
i will be re making it out of steel. turned it over at 200rpm easy.
also just adapted a mitzi starter to fit a bda. (same patern as pint0) was also gear reduction but inline planetary gears.
a big battery helps when using old technology shit tho.
(running 12.1.1 compression)
Thatll do it! You running forged pistons cause thats alot of CR for a pinto!
Roadrunner do geared starters for around $250.. BUT I think from the above that your running a W50 not a Sierra type 9? If so then adaption is your only real choice.
Gaz
Try Auto Electric Spares in Henderson They modified a standard cortina starter for me I was running a little bit higher compression & it was melting starters. Just take in the starter you have & they'll modify it to suit. Bit exspensive, but well worth it
