Elmo2003 Posted November 8, 2010 Share Posted November 8, 2010 hey guys having a few issues trying to find a high power starter motor to fit my motor and gearbox as the one i have now lacks power to crank my engine over Any Ideas would be great Cheers Quote Link to comment Share on other sites More sharing options...
Horse25 Posted November 8, 2010 Share Posted November 8, 2010 so if your using a w50 gearbox, what kind of bellhousing are you using? not a dellow? Quote Link to comment Share on other sites More sharing options...
peteretep Posted November 8, 2010 Share Posted November 8, 2010 hard to believe that it wont turn a motor over, have you taken the starter motor to an auto electrician? from memory its about $175 to get a starter rebuilt Quote Link to comment Share on other sites More sharing options...
Elmo2003 Posted November 8, 2010 Author Share Posted November 8, 2010 nt sure on bellhousing as it was already on motor wen i gt both of them the starter motor turns motor over jst not fast and takes for ever to start (running 12.1.1 compression) Quote Link to comment Share on other sites More sharing options...
peteretep Posted November 8, 2010 Share Posted November 8, 2010 Getting the starter rebuilt should solve the slow turning over Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 8, 2010 Share Posted November 8, 2010 gaz had some mad geared started motor on his pinto, give him a PM to find out what he had Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted November 9, 2010 Share Posted November 9, 2010 i adapted a big block chev aftermarket gear reduction starter for my pinto. 2.5horse power! worked a treat! untill the raw power of the starter broke its own mounts. i will be re making it out of steel. turned it over at 200rpm easy. also just adapted a mitzi starter to fit a bda. (same patern as pint0) was also gear reduction but inline planetary gears. a big battery helps when using old technology shit tho. Quote Link to comment Share on other sites More sharing options...
Elmo2003 Posted November 9, 2010 Author Share Posted November 9, 2010 have u gt ne pics of the v8 adaptor one that you are using Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted November 9, 2010 Share Posted November 9, 2010 http://www.trademe.co.nz/Trade-Me-Motor ... 794962.htm was one of these, i just removed the bolting plate and mdoifyed to fit Quote Link to comment Share on other sites More sharing options...
Gaz Posted November 9, 2010 Share Posted November 9, 2010 (running 12.1.1 compression) Thatll do it! You running forged pistons cause thats alot of CR for a pinto! Roadrunner do geared starters for around $250.. BUT I think from the above that your running a W50 not a Sierra type 9? If so then adaption is your only real choice. Gaz Quote Link to comment Share on other sites More sharing options...
sholdowa Posted November 21, 2010 Share Posted November 21, 2010 Some people add a switch into the ignition circuit so you can get it spinning before firing, due to the advance often necessary. Quote Link to comment Share on other sites More sharing options...
escy274 Posted November 21, 2010 Share Posted November 21, 2010 Try Auto Electric Spares in Henderson They modified a standard cortina starter for me I was running a little bit higher compression & it was melting starters. Just take in the starter you have & they'll modify it to suit. Bit exspensive, but well worth it Quote Link to comment Share on other sites More sharing options...
