Fuel filter bowl / water seperator
Lump
The water fuel separator bowl started leaking around the adjustable tap earlier this year and I removed it and replaced it with an inline filter.
I'd like to replace it as I occasionally have problems with water in the fuel and the bowl gave a quick visual check. I have seen these in other cars such as escorts etc. Here's one that looks similar
http://www.mossmotors.com/Shop/ViewProd ... exID=56348
I've had a look on trade me but I can only find marine style products is there anywhere in NZ where I can get one?
I'm fairly sure I've seen something similar (noted because the Prince runs one) in E Hayes & Son down here (local Hammer Hardware) they cater for small bore engines and all manner of crap so, possibly a similar place up north will do the same.
Its leaking from under the adjustable tap, I have pulled it apart before and it doesn't use an o ring in that part - the seal is like a flat discus and I don't think it could be replaced.
a seal like a doughty type washer ( may have that spelt wrong )
which is like a metal ring with a rubber in-sert in the middle?
if so just hit down to your local hyd shop and get some simple fix
shit me that looks like the old water trap of a xa coon of sorts ( how i miss that whale of a car )
fyi
alot of parts places dont list these as water trap/seperator filters they have them down as fuel filters, and most young cats will not know what one is
but i would also try any ford/holden wreaker
