Testament Posted April 29, 2010 Share Posted April 29, 2010 yeah carbs will be bigger on a 3cyl for the same displacement as the cylinders are bigger and carb size will be proportional to that providing rpm and output are the same. Quote Link to comment Share on other sites More sharing options...
vvega Posted April 29, 2010 Share Posted April 29, 2010 I never said that 250hp was what I am after, the only mention of attaining a power figure that I made was that I would like to try and replicate the standard 89.5kw, which is 120hp. I've seen 1.6 SOHC G-series gemini engines make this sort of power.Any upgrades to the engine, i.e cam grind, extractors/exhaust, increased comp. ratio, head work, and it would be a bonus to make some extra power/torque. That said, I'd say that the standard power/torque figures for this engine would pull a sub 900kg car along quite nicely. sory zeb i didnt read the whole threed what hp do you think it will make ? if you can get something flatslide or with a accel pump it will go much nicer Quote Link to comment Share on other sites More sharing options...
