filthy one Posted March 19, 2010 Share Posted March 19, 2010 Yo anyone no if low fluid would cause my trans to not shift into 3rd ?? It goes from 1st to 2nd all good in drive & manually shifting but not into 3rd.. its all good other than that but mmmmmmm not happy & I ran out of light Quote Link to comment Share on other sites More sharing options...
smokin' joe Posted March 20, 2010 Share Posted March 20, 2010 had a Falcon on the hoist this week that had the same issue. drained fluid, fitted new filter, topped her up and all was good. Quote Link to comment Share on other sites More sharing options...
cletus Posted March 20, 2010 Share Posted March 20, 2010 vacuum modulator not hooked up/not working? trans may think engine is at WOT and not shift into top until high rpm Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted March 21, 2010 Share Posted March 21, 2010 Yeah I had a vacuum hose come off mine in the 5I and it would not change into 3rd/sometimes any gears, hopefully its something simple like that. Quote Link to comment Share on other sites More sharing options...
filthy one Posted March 21, 2010 Author Share Posted March 21, 2010 na think its fucked . I found out its got a manual shiftkit fitted so I disconnected the vac hose & now it shifts into 3rd smooth but slips . As in the engine revs but the car doesn't pick up speed then it kind of grabs hold & will drive ok. It drives fine cruising in 3rd but try to speed up & she slips .. Talked to a mate who works for a trans shop hes suggested a bottle of Lucas trans slip fluid apperantly its bloody good & because the trans has been sitting for a couple of years he said it may have a shitty film on the plates & need a bit of use etc ..Might as well try it i guess only other option it take the fucker out again .. I have a full rebuilt kit $300/400 so i guess it not the end of the world .Just such a shit to take it out again Quote Link to comment Share on other sites More sharing options...
KKtrips Posted March 22, 2010 Share Posted March 22, 2010 have you checked the linkage isn't fouling and preventing it from selecting 3rd? Quote Link to comment Share on other sites More sharing options...
filthy one Posted March 22, 2010 Author Share Posted March 22, 2010 have you checked the linkage isn't fouling and preventing it from selecting 3rd? yeah mate it selects 3rd sweet as now but its slips real bad Quote Link to comment Share on other sites More sharing options...
KKtrips Posted March 22, 2010 Share Posted March 22, 2010 hmmmm damn would guess the bands would either need adjustment or the clutches are toast. does it launch hard in first? Quote Link to comment Share on other sites More sharing options...
filthy one Posted March 22, 2010 Author Share Posted March 22, 2010 hmmmm damn would guess the bands would either need adjustment or the clutches are toast.does it launch hard in first? yep fries tyres first & well into 2nd but 3rd just goes weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeyeeerrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr Quote Link to comment Share on other sites More sharing options...
KKtrips Posted March 22, 2010 Share Posted March 22, 2010 adjustment won't fix that then - clutches would be well fucked if thats the case.. get trans builder to chuck some extra clutch plates in there if you plan on doing mucho skids.. (oh BTW I don't know fuck all about TH350's - I am thinking about P-Glides and assuming hop up options will work for TH350's on the same basis) Quote Link to comment Share on other sites More sharing options...
