LILVR4 Posted March 18, 2010 Share Posted March 18, 2010 as title would a gsr motor rwd as easy as a evo 4g63 Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted March 19, 2010 Share Posted March 19, 2010 Since the other thread has been locked ill chuck my question for Fuel up hurr Can you bolt Evo 4,5,6 heads on to say, a Starion block or Evo 1,2,3 block? Would that fix the problem of no engine mount castings and bellhousing differences? Quote Link to comment Share on other sites More sharing options...
fuel Posted March 19, 2010 Share Posted March 19, 2010 as title would a gsr motor rwd as easy as a evo 4g63 early 4G93 uses same bellhousing pattern as the VR-4/Evo1-3 engine but you'll have RWD flywheel issues. The 4G93 block doesn't have the castings for RWD mounts either. I wouldn't recommend the 4G93, if you push them too hard they run bearings and will throw a rod out the side of the block. Quote Link to comment Share on other sites More sharing options...
fuel Posted March 19, 2010 Share Posted March 19, 2010 Since the other thread has been locked ill chuck my question for Fuel up hurrCan you bolt Evo 4,5,6 heads on to say, a Starion block or Evo 1,2,3 block? Would that fix the problem of no engine mount castings and bellhousing differences? Oil drains are in the wrong place from memory, basically the head is just mirrored from one side to the other - you can even use an Evo4+ rocker cover on an evo1-3 engine but the cambelt covers wont interchange. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted March 19, 2010 Share Posted March 19, 2010 You sure about the mount castings Phil? There was a fellow on here to dropped one in his EX, from memory it was a bolt in jobbie Quote Link to comment Share on other sites More sharing options...
LILVR4 Posted March 19, 2010 Author Share Posted March 19, 2010 ok sweet thanks phil , i just iv got a 79 sigma just sitting there and cant realy afford anther 4g63 lol my 78 sigma 4g63 dohc is coming along great what about a 4g61t i know it only a 1600 but cheaper than 4g63s Quote Link to comment Share on other sites More sharing options...
LILVR4 Posted March 19, 2010 Author Share Posted March 19, 2010 what about the 4g61t dohc? Quote Link to comment Share on other sites More sharing options...
dwlee Posted March 20, 2010 Share Posted March 20, 2010 I have seen 4g92 mivec engines fitted rwd drive in an LA Lancer (major firewall mods) and in an Escort (do a google search under mivec escort) so since the 4g93 block is basically the same it is possible. I know it will be more complex than fitting a 4g63, but I don't by how much. A 4g61 block is basically the same as the 6-bolt 4g63 accept they don't have balance shafts fitted and deck height is 6mm lower (hence the 4g63 rwd water pump will not fit). The difficulty level in fitting a 4g61t is the same as fitting a 4g63t. Quote Link to comment Share on other sites More sharing options...
H05TYL Posted March 21, 2010 Share Posted March 21, 2010 go to pick-a-part get an n/a 4G63 for peanuts --> job done Quote Link to comment Share on other sites More sharing options...
