d.p.n.s Posted March 8, 2010 Share Posted March 8, 2010 good work mate. so your getting the hang of it? dan Quote Link to comment Share on other sites More sharing options...
Horse25 Posted March 8, 2010 Share Posted March 8, 2010 yeah getting there, also por 15 the inside of the drivers door, forgot i had a couple of donor doors that have rusted out on the opposite side, so i will use the exact pieces from that i guess? Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted March 8, 2010 Author Share Posted March 8, 2010 yeah getting there, also por 15 the inside of the drivers door, forgot i had a couple of donor doors that have rusted out on the opposite side, so i will use the exact pieces from that i guess? yeah man cut them up save you having to make the bits you need. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted March 9, 2010 Share Posted March 9, 2010 im freeish on Sunday boe can lend a hand will have you paint ect by then aswell Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted March 9, 2010 Share Posted March 9, 2010 ps. would i be able to get the lancer dropped off during the day this week? truck driver wont do after hours Quote Link to comment Share on other sites More sharing options...
Horse25 Posted March 9, 2010 Share Posted March 9, 2010 ps. would i be able to get the lancer dropped off during the day this week? truck driver wont do after hours sweet sounds good, any day is good to drop lancer off, what is best for you? Quote Link to comment Share on other sites More sharing options...
peteretep Posted March 16, 2010 Share Posted March 16, 2010 hey man what was the master cylinder you used? it doesnt look like it bolts up to the original flange like a standard unit? Does your car have the mk2 pedal box or mk1? what was the deal with the shaft? Quote Link to comment Share on other sites More sharing options...
Horse25 Posted March 16, 2010 Share Posted March 16, 2010 hey man what was the master cylinder you used? it doesnt look like it bolts up to the original flange like a standard unit? Does your car have the mk2 pedal box or mk1? what was the deal with the shaft? It's off a land rover, 22mm bore, yeah vertical mounts, but got a good price on it so makes up for that, using a mk2 pedal box, as for the shaft, we found a bolt at the right length and welded it on to the bracket, as all it requires is a flat shaft end, Ive just bought a 1inch bore land rover master with the right mounting brackets etc, same type that QCADTA used, double the price though. can take pics if you want? Quote Link to comment Share on other sites More sharing options...
peteretep Posted March 16, 2010 Share Posted March 16, 2010 yeah man that would be great, im looking at ditching my booster too, I have also heard about using the 25mm land rover unit, any info on them would be great. Have you used your brakes at all? im really interested in finding out how heavy the pedal is how have you run the lines? did you use a proportioning valve at all? howcome you bought another master cylinder? Quote Link to comment Share on other sites More sharing options...
Horse25 Posted March 16, 2010 Share Posted March 16, 2010 yeah man that would be great, im looking at ditching my booster too, I have also heard about using the 25mm land rover unit, any info on them would be great. Have you used your brakes at all? im really interested in finding out how heavy the pedal ishow have you run the lines? did you use a proportioning valve at all? howcome you bought another master cylinder? ill try get some more info, the other master cylinder is for the other car. haven't used the brakes yet, but we did a full bleed and they feel really solid now, was warned to have a play before i go on the road as the bite time will be different. as for the lines i bought new valve parts(idk right name) and just cut the old lines and made them to suit. not using a proportioning valve, don't have a use for it at this stage as far as i can see? Quote Link to comment Share on other sites More sharing options...
QCADTA Posted March 16, 2010 Share Posted March 16, 2010 pedals firm but still locks up under hard braking. just have to make a retaining bush for the actuating arm from the pedal as there is no internal circlip on the landrover m/c like the escort one. other than that a piece of piss to sort. Quote Link to comment Share on other sites More sharing options...
peteretep Posted March 16, 2010 Share Posted March 16, 2010 any pics of this stuff would be great , where did you guys get the master cylinder(part number?) and what did it cost? proportioning valve would be used if your rear brakes lock up before your fronts new valve parts? other than the master cylinder what else did you need apart from fittings? Quote Link to comment Share on other sites More sharing options...
QCADTA Posted March 16, 2010 Share Posted March 16, 2010 i didnt need a proportioning valve as the hilux rear end i have matches the landrover m/c. didnt need a thing, just changed it over with the bush i made.could draw a pic tomorrow. mine was $258 from memory. series 2 landrover. Quote Link to comment Share on other sites More sharing options...
peteretep Posted March 16, 2010 Share Posted March 16, 2010 yeah a picture of the inside of the unit would be cool too , what rod did you use QCADTA? Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted March 16, 2010 Author Share Posted March 16, 2010 all ive ever done is just use the master cylinder from a mk3/4/5 cortina bolts up to the same holes and uses the same brake lines as the mk2 and for the rod i just measures the lengh i needed and cut the long barke booster one down. cheers dan Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 16, 2010 Share Posted March 16, 2010 all ive ever done is just usethe master cylinder from a mk3/4/5 cortina bolts up to the same holes and uses the same brake lines as the mk2 and for the rod i just measures the lengh i needed and cut the long barke booster one down. cheers dan Same way I did it, except I had to file the hole in the firewall out a few mm's to get the master to fit in. The Ford master cylinder should provide ample stopping power too, I ran a tiny little hillman hunter master cylinder for ages in my old van, pedal felt mint and it stopped sweet as -the hunter master is a single line out cylinder with a really small bore. Oh yeah MK2 Escorts, some Transits, Sierra's etc use the same master cyl as mk3/4/5 Cortinas (along with the same calipers and drums) Quote Link to comment Share on other sites More sharing options...
peteretep Posted March 19, 2010 Share Posted March 19, 2010 ive rung around a few places and i think the land rover part number from PBR is P7810 which has a 25mm bore, but Ive just been quoted $81+gst, which is alot more than the $258 you thought QCADTA, dont suppose you remember a part number at all?? Quote Link to comment Share on other sites More sharing options...
Horse25 Posted March 19, 2010 Share Posted March 19, 2010 Part number : 90577520 part description Cyl B/M 109 tandem 1" Hope this helps Cheers David Quote Link to comment Share on other sites More sharing options...
peteretep Posted March 19, 2010 Share Posted March 19, 2010 whats it worth and what brand?? Quote Link to comment Share on other sites More sharing options...
peteretep Posted March 20, 2010 Share Posted March 20, 2010 NRC6096 is the later metric version of the same part number up there as far as I can tell I found this too, apparently a ford explorer unit does the trick as well, but i cant find any information on it, cylinder size etc, but you'd imagine it would be pretty big http://www.lrfaq.org/Series/HydraulicsA ... aster.html Quote Link to comment Share on other sites More sharing options...
