grdwalker Posted November 17, 2009 Share Posted November 17, 2009 i know you can swap the suspension from the 2litres (leafs and struts) but does that mean you need new brakes? or are the two systems completely separate from each other? Quote Link to comment Share on other sites More sharing options...
Gaz Posted November 18, 2009 Share Posted November 18, 2009 huh what? From the 2l what? The RS2000??? Mk2 escort usually already has the large dia discs up front. The larger rear drums came out on RS2000, Ghais, and sports. I have a set of bth if you wanted to upgrade. Gaz Quote Link to comment Share on other sites More sharing options...
grdwalker Posted November 19, 2009 Author Share Posted November 19, 2009 all the guides say the "2L" so i apologise if i cant be more specific (im referring to the spannerfodder pinto into eskie guide) Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 19, 2009 Share Posted November 19, 2009 Standard Mk2 suspension and breaks should be fine man Quote Link to comment Share on other sites More sharing options...
Raizer Posted November 19, 2009 Share Posted November 19, 2009 I'm curious as to what "2L brakes" are, since the 2L Cortinas and some 3L Capri's have the exact same caliper with the same size master cylinder and disks as a mk2 Escort Quote Link to comment Share on other sites More sharing options...
grdwalker Posted November 20, 2009 Author Share Posted November 20, 2009 i thought everything might have been stiffened a bit for the added "power" Quote Link to comment Share on other sites More sharing options...
Gaz Posted November 20, 2009 Share Posted November 20, 2009 Cortina discs are thicker than escort. They are the same dia tho. Calipers the same. Gaz Quote Link to comment Share on other sites More sharing options...
BS5620 Posted November 20, 2009 Share Posted November 20, 2009 Cortina discs are thicker than escort In general is it better to have thicker discs?? or six in one half dozen in the other situation, I ask because check the difference between my cortina and capri ones!! Which would be best to use?? Quote Link to comment Share on other sites More sharing options...
sholdowa Posted November 20, 2009 Share Posted November 20, 2009 the thicker the disk, the more fade resistant they are... more metal to heat. If you are after an upgrade, the 2.8 crappi venteds, and a spacer for your calipers is a good option, and fit straight on. Quote Link to comment Share on other sites More sharing options...
Gaz Posted November 21, 2009 Share Posted November 21, 2009 Capri and Cortina brakes are the same... except for the 2.8i injected capri discs. 2.8i capri discs are the same dia but vented. IMO unless racing the vented disc is not worth it. I run the capri/cortina thicker disc. None of these ,entioned brakes will give you any better braking than the standadr escort brake but they will help decrease brake fade which means you can brake at full force for a longer time. Gaz Quote Link to comment Share on other sites More sharing options...
