mk2 escort suspension change
grdwalker
Capri and Cortina brakes are the same... except for the 2.8i injected capri discs. 2.8i capri discs are the same dia but vented. IMO unless racing the vented disc is not worth it. I run the capri/cortina thicker disc.
None of these ,entioned brakes will give you any better braking than the standadr escort brake but they will help decrease brake fade which means you can brake at full force for a longer time.
Gaz
