Beaver Posted September 13, 2009 Share Posted September 13, 2009 hey all. my trusty 83 delica just surving the hell that is undie 500, and made the ctrip from chch to duniden and back with out any issues, but now has developed some nasty symptoms, and and hoping someone can give me an idea on what myt be causing them.... it has always had a shit idle, ie real grumpy and ranges jumps around a fair bit, almost spluttering. smells like its running rich but checked a plug and looked prety good, tried mixture screw (well at least i think it was) but to now avail. also, when taking foot of the go pedal it will often crackle pop and back fire (not once or twice but at random intervals, ie going down a hill it will do it again and again). also, it has uber over run, ie when i turn the key off it stumbles for 5-10 seconds then goes vroom and stops....i think its haunted is there something that would be causing these all?> cheers Quote Link to comment Share on other sites More sharing options...
Requiemk Posted September 13, 2009 Share Posted September 13, 2009 is not directly related to all of the above but bypass your fuel filter or get a new one and see if it changes Quote Link to comment Share on other sites More sharing options...
cheater_5 Posted September 13, 2009 Share Posted September 13, 2009 I had this in my truck, real bad at times a while ago. I think I had mad crap in my fuel tank/filter/bowl and was stopping and starting fuel flow. Ended up cleaning out tank, blowing out lines and shit etc. Think that's how I fixed it. So yeah, do what ^he says and see if it helps. Check your timing? Check dist cap isn't corroded up? Does the carb have a float bowl window at all? I'm calling fuel but it'd take 2 mins to check those anyway Quote Link to comment Share on other sites More sharing options...
Beaver Posted September 13, 2009 Author Share Posted September 13, 2009 I had this in my truck, real bad at times a while ago. I think I had mad crap in my fuel tank/filter/bowl and was stopping and starting fuel flow. Ended up cleaning out tank, blowing out lines and shit etc. Think that's how I fixed it. Check your timing? Check dist cap isn't corroded up? Does the carb have a float bowl window at all? ive actually been meaning to chamge fuel filter as twice i have just lost power and it wont rev, but then after a moment or 7 it clears its self out and runs fine. Quote Link to comment Share on other sites More sharing options...
forced Posted September 13, 2009 Share Posted September 13, 2009 The auto choke has probably crapped out and the owner fiddling with other things probably made it worse. A pic of the plugs would help. Steve Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted September 13, 2009 Share Posted September 13, 2009 it is defiantly haunted its spirit is asking for a new power plant, probably by means of some churbros and 4g64's Quote Link to comment Share on other sites More sharing options...
Chrome_GT Posted September 13, 2009 Share Posted September 13, 2009 Over run is caused by hot stuff in the combustion chamber such as hot valves or hot carbon deposits. This hot stuff will also be causing early or late random misfires while running (preignition / pinking). The hot stuff will be caused either by a too retarded ignition timing or a lean mixture. So check your ignition timing or just mark it as is then try advancing it. You can always go back to that mark. I would avoid stuffing with the mixture until you are sure the timing is correct. I also found i got those symptom when using 91 Octance in a car setup for 96 Octance. Quote Link to comment Share on other sites More sharing options...
Requiemk Posted September 14, 2009 Share Posted September 14, 2009 Over run is caused by hot stuff in the combustion chamber such as hot valves or hot carbon deposits. This hot stuff will also be causing early or late random misfires while running (preignition / pinking). The hot stuff will be caused either by a too retarded ignition timing or a lean mixture. So check your ignition timing or just mark it as is then try advancing it. You can always go back to that mark. I would avoid stuffing with the mixture until you are sure the timing is correct. I also found i got those symptom when using 91 Octance in a car setup for 96 Octance. inconsistent fuel supply would cause lean conditions which leads to overrunning Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted September 14, 2009 Share Posted September 14, 2009 mitsis are gay as fuck for running on. set the timing as per factory and ask ogre what he did to stop his doing it. factory carbs on these are balls. webers rarely run on Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted September 14, 2009 Share Posted September 14, 2009 take dizzi cap off and give the shaft a wiggle. if its quite bad theres your problem id say. worn bushes. Quote Link to comment Share on other sites More sharing options...
Horse25 Posted September 27, 2009 Share Posted September 27, 2009 I went for a trip down to dunners and back in the van, started having the same symptoms, found that my points had closed up, so maybe check your points gap? Quote Link to comment Share on other sites More sharing options...
Beaver Posted September 27, 2009 Author Share Posted September 27, 2009 cheers for the tips, have now sold the van so not my problem anymore lol Quote Link to comment Share on other sites More sharing options...
