Beaver Posted May 6, 2009 Author Share Posted May 6, 2009 I wish I was in your shed/ nah probably too cold (it is 8 degress in mine so yours must be worse).Please check the pilot bearing hole in the crankshaft with a torch if you have not already................. and some photos might help this cause if you get a chance haha i wish u were in my shed too!! nah it wasnt to cold actually. have called it a day for today, back home now as the car is out at a mates. have tracked down old gearbox that used to be in car and am going to try that out when i next get the chance, and hopefully it works, which confirms that its the input shaft, in which case i will get another gbox. i insepcted the pilot bearing hole, and you could see that something had been grabbing, but there was no damage. at this stage i am 99.9999% sure that it will work perfectly with the old gbox back in Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 8, 2009 Author Share Posted May 8, 2009 IT MOVES!!!!!!!!!! turns out we were on the right track, but hadnt taken enough of the input shaft. put the old gbox back in and workd a treat thanks for all the help guys Quote Link to comment Share on other sites More sharing options...
Unclejake Posted May 10, 2009 Share Posted May 10, 2009 Good work. Now you need to pay attention to crank end float and you will have probably damaged the trust washer. Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 10, 2009 Author Share Posted May 10, 2009 Good work.Now you need to pay attention to crank end float and you will have probably damaged the trust washer. what sort of things should i be looking out for? Quote Link to comment Share on other sites More sharing options...
Raizer Posted May 11, 2009 Share Posted May 11, 2009 Pull and push on your front crank pulley, does the crank move at all? Get a click noise each way? If yes you need to drop the sump and at least change the thrust washers. *There is probably better and more accurate ways to check. Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 11, 2009 Author Share Posted May 11, 2009 Pull and push on your front crank pulley, does the crank move at all? Get a click noise each way?If yes you need to drop the sump and at least change the thrust washers. *There is probably better and more accurate ways to check. i think i can manage that haha, will check next time i go out to the car (it at a mates) Quote Link to comment Share on other sites More sharing options...
