Stacov Posted March 23, 2009 Share Posted March 23, 2009 heyas Im looking at putting a seirra 5spd onto my 1600 crossflow, anyone done this and knows exactly what needs to be done All i know is u gotta mod the flywheel to fit the sierra clutch,make gearbox tunnel bigger,mod driveshaft to suit etc.. so yea any info would be great if its too much trouble then ill go with my other plan and put the 2L pinto in there lol. Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 23, 2009 Share Posted March 23, 2009 You need to take a few mm off the input shaft of the box, otherwise it pushes your crank forward and can fuck your thrust washers. If you don't want to have the flywheel redrilled you can use a Hillman Hunter clutch disc and a stock Xflow pressure plate. You might not even have to mode your tunnel since the Xflows seem to sit lower than a Pinto engine. The stock speedo cable is too short but you can use one from a pinto cortina. Edit: Apparently you can use a crossmember from an auto Escort to mount the box (I think EXCORT on here use's one?) other wise you can use the Sierra crossmember bolted through the floor with plates on top of the floor. You will either have to cut the tunnel for the shifter to come through or get the box modified so the shifter comes through the stock hole (I know someone on here has done it to there's) Quote Link to comment Share on other sites More sharing options...
Mr.Mk1 Posted March 23, 2009 Share Posted March 23, 2009 Do the 2L. Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 23, 2009 Share Posted March 23, 2009 Do the 2L. FTL Quote Link to comment Share on other sites More sharing options...
BS5620 Posted March 24, 2009 Share Posted March 24, 2009 Yup use the hillman clutch plate(way cheaper) or you can get special ones mad up. No need to mod the tunnel with the 1600 xflow engine, it just fits (could gently massage with a hammer if needed anyways ) I would use the sierra x-member bolted through the floor, way easier. Use a single piece driveshaft (cortina/anglia) would be way easier, but the you gotta change the nose so it fits the g-box I did the convo to my mk1 cortina and my mates mk2 esky wag. Engine runs real nice with the 5 speed Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted March 24, 2009 Share Posted March 24, 2009 Edit: Apparently you can use a crossmember from an auto Escort to mount the box Yup yup this is what i have done. Quote Link to comment Share on other sites More sharing options...
Stacov Posted March 25, 2009 Author Share Posted March 25, 2009 Yup use the hillman clutch plate(way cheaper) or you can get special ones mad up. No need to mod the tunnel with the 1600 xflow engine, it just fits (could gently massage with a hammer if needed anyways ) I would use the sierra x-member bolted through the floor, way easier. Use a single piece driveshaft (cortina/anglia) would be way easier, but the you gotta change the nose so it fits the g-box I did the convo to my mk1 cortina and my mates mk2 esky wag. Engine runs real nice with the 5 speed sweet sounds like a worth wild mod to do no fun driving on the highway doing 4000 revs haha uses more petrol then my wrx Yeah i have a single piece driveshaft so no need to shorten it or anything ? just change the input nose for it to fit the g/box? and im pretty sure i still have the sierra x-member too so thats a bonus Quote Link to comment Share on other sites More sharing options...
Stacov Posted March 25, 2009 Author Share Posted March 25, 2009 Oh yea i have a hyraulic pedal setup do i have to change to cable clutch or will i beable to use my hyraulic setup on the 5spd? Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 25, 2009 Share Posted March 25, 2009 sweet sounds like a worth wild mod to do no fun driving on the highway doing 4000 revs haha uses more petrol then my wrx Yeah i have a single piece driveshaft so no need to shorten it or anything ? just change the input nose for it to fit the g/box? and im pretty sure i still have the sierra x-member too so thats a bonus I'm guessing this is for a Cortina rather than an Escort? Depending on the model of Tina you will still have to get the shaft shortened (If you have a 1600 MK3 then its the right length) Oh yea i have a hyraulic pedal setup do i have to change to cable clutch or will i beable to use my hyraulic setup on the 5spd? I have seen hydraulic kits for Sierra boxes being sold by Burton's but for the cost involved I would convert to cable! Quote Link to comment Share on other sites More sharing options...
Stacov Posted March 25, 2009 Author Share Posted March 25, 2009 Yea sorry should of said it was for a mk2 cortina Cable clutch would be the go, not rich enough to buy from burtons Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 25, 2009 Share Posted March 25, 2009 Might be able to adapt an Escort clutch pedal into the Tina too. Quote Link to comment Share on other sites More sharing options...
Stacov Posted March 25, 2009 Author Share Posted March 25, 2009 So is it just the clutch i need either hilliman hunter,sierra or the pressure plate aswell i got a brand new clutch/presssure plate from one of my 2l pinto motors out of a old mk5 cortina i wreckd should be good with the 5spd yea? sorry for all the questions just gathering all the info haha i doubt anyone here in dannevirke has done this converstion before. I askd my mechanic but he didnt know much about it. Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 25, 2009 Share Posted March 25, 2009 So is it just the clutch i need either hilliman hunter,sierra or the pressure plate aswelli got a brand new clutch/presssure plate from one of my 2l pinto motors out of a old mk5 cortina i wreckd should be good with the 5spd yea? sorry for all the questions just gathering all the info haha i doubt anyone here in dannevirke has done this converstion before. I askd my mechanic but he didnt know much about it. If you get your flywheel machined and redrilled to take the larger clutch you can use the Pinto clutch and pressure plate. You use the Hunter clutch with a stock Xflow pressure plate. The Hillmans have the same size clutch as a Xflow but with the larger spline that the Pinto gearboxes use. Quote Link to comment Share on other sites More sharing options...
Stacov Posted March 25, 2009 Author Share Posted March 25, 2009 ahh choice thanks for that, yea i was thinking of just get my flywheel redrill as i was going to get it lightned at the same time Quote Link to comment Share on other sites More sharing options...
