tortron Posted September 30, 2008 Share Posted September 30, 2008 need to make the holes on my steels a few mm wider to fit over my hubs how/with what/anyone in hams got a lathe Quote Link to comment Share on other sites More sharing options...
Requiemk Posted September 30, 2008 Share Posted September 30, 2008 wtf iv said it in like 3 threads already Quote Link to comment Share on other sites More sharing options...
tortron Posted September 30, 2008 Author Share Posted September 30, 2008 cant see how that would be round at all Quote Link to comment Share on other sites More sharing options...
Requiemk Posted September 30, 2008 Share Posted September 30, 2008 you do it carefully. file edges if keen on super circilised Quote Link to comment Share on other sites More sharing options...
Unclejake Posted September 30, 2008 Share Posted September 30, 2008 need to make the holes on my steels a few mm wider to fit over my hubshow/with what/anyone in hams got a lathe Normally better to get the correct centre bore size on the wheels (without modifying them) for turn a wee bit off the cast dust cap locating neck of the hub. There is usually enough material there to get away with it so long as you are not looking for a substanial change.EDIT: I just realised this is probably for a Morris Minor which if I recall correctly from 25 years ago has a cast front drum that also houses the outer wheel bearing which may make the job different. Get a Honda Quote Link to comment Share on other sites More sharing options...
tortron Posted September 30, 2008 Author Share Posted September 30, 2008 yea it has 4 prong dealies on the brake drum its self will attack em with a grinder tomorow for lols Quote Link to comment Share on other sites More sharing options...
tortron Posted September 30, 2008 Author Share Posted September 30, 2008 the wheels that is, fuck altering unobtanium Quote Link to comment Share on other sites More sharing options...
Unclejake Posted September 30, 2008 Share Posted September 30, 2008 yea it has 4 prong dealies on the brake drum its selfwill attack em with a grinder tomorow for lols Not what I would do but in all honesty it will probably be sweet if you have no easy alternative. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted September 30, 2008 Share Posted September 30, 2008 the wheels that is, fuck altering unobtanium That Is Yuck. Shave the hubs/drums. Quote Link to comment Share on other sites More sharing options...
tortron Posted September 30, 2008 Author Share Posted September 30, 2008 how? Quote Link to comment Share on other sites More sharing options...
Guest vvega Posted September 30, 2008 Share Posted September 30, 2008 have lather etc......... Quote Link to comment Share on other sites More sharing options...
CUL8R Posted September 30, 2008 Share Posted September 30, 2008 lather, fuck would be there till christmas, perhaps a lathe would be better? Quote Link to comment Share on other sites More sharing options...
tortron Posted October 2, 2008 Author Share Posted October 2, 2008 attempted grinder - decided fuck no this is just going to fuck evertyhing so who in hams has a lathe/who are some gc engineers etc Quote Link to comment Share on other sites More sharing options...
fuel Posted October 2, 2008 Share Posted October 2, 2008 it wont be cheap if you get an engineer to do it - I had a set of alloys done and it cost about $100 for the lot. Thing is with a steel wheel the centre bore is usually a pressed up lip, so if you machine that (depending how much you machine it), you'll loose both strength on height and width of the centrebore on the actual rim. Could you not just find some Mitsubishi/Nissan 4x114.3mm steels instead? they have a big centrebore size compared to Toyota etc. Quote Link to comment Share on other sites More sharing options...
tortron Posted October 2, 2008 Author Share Posted October 2, 2008 oh yea, i might keep a look out for them then had a measure and its quite a bit of meat needs to come off Quote Link to comment Share on other sites More sharing options...
