escort clutch and gear box
rs2000escort
hey , i was putting the clutch and pressure plate back on my girls 1600 crossflow on the weekend it has a lightened flywheel and a new standard clutch and pressure plate that have previouly fitted and diving on for around 200k's so not long before the motor and box where taken out for the engine to be rebuilt, when i went to put the clutch and p/plate on i noticed the p/plate was around 5mm off the flywheel but put the bolts in and it pulled it in, then i put the gear box on that ws not touch, when i had it all together the realease fork that stick out the side of the box for the clutch cable it supper hard and want go either way forward or backwards, then i fitted the starter etc etc and hooked up a battery to start - gear box in neutrel but it would turn over as if the clutch was ingaged have previous had motor running with box on but not clutch etc etc so i span the crank and the shaft span at the back of the box.
anyone have any ideas on what i should check when i pull the box back off ??
Cheers for your help David
dont be offended,but was the clutch plate around the right way?
seen it done before
My first thought too....
Except for:
which I really don't understand but if it is written out again may suggest that the input shaft or input shaft housing is fouling the driven plate. It happens with some Ford transmissions
RS2000 - can you explain the bit in bold text again?
