nobumps Posted April 4, 2008 Share Posted April 4, 2008 Anyone got some good tips on pulling out dents on sills? theyre not to big quite short and sharp dents like the shape of a V. Quote Link to comment Share on other sites More sharing options...
nobumps Posted April 4, 2008 Author Share Posted April 4, 2008 Come on surley some has before?? Quote Link to comment Share on other sites More sharing options...
fuel Posted April 4, 2008 Share Posted April 4, 2008 if you're going to be bogging over them then drill a hole in the middle of the dent (or dents) and use a slide hammer to pull the dents out. You have pretty limited access with sills so unless you can get in behind the dent you wont be able to get the dent out 100%. Quote Link to comment Share on other sites More sharing options...
tortron Posted April 4, 2008 Share Posted April 4, 2008 slide hammer/one of those new fancy ones that welds itself to the dent rather than putting a hole in it - is probably the best/easiest. The only other thing i can think of for a sill is to perhaps cut it out and put a new bit in if you can get some access into behind it you may be able to jam a deflated ball in behind there, inflate it and the dent should pop out quite nicely (assuming its not too badly stretched) - good way to straighten out the front of kombis Quote Link to comment Share on other sites More sharing options...
Rusted Posted April 5, 2008 Share Posted April 5, 2008 slide hammer/one of those new fancy ones that welds itself to the dent rather than putting a hole in it - is probably the best/easiest. I knew those as Hot rivet guns. However the guy doing the panel on the B has never heard or used one. He thought I was full of BS. Quote Link to comment Share on other sites More sharing options...
durty Posted April 5, 2008 Share Posted April 5, 2008 we have one of those things at work is forkin choice Quote Link to comment Share on other sites More sharing options...
