SHGWAG Posted April 1, 2008 Author Share Posted April 1, 2008 Heres a pic Whats that grey box on top rite of pic behind coil?? Quote Link to comment Share on other sites More sharing options...
Spencer Posted April 1, 2008 Share Posted April 1, 2008 pies boe crowns pretty different mounting being full chassis and all but can give you a set of plates to start with Quote Link to comment Share on other sites More sharing options...
Unclejake Posted April 1, 2008 Share Posted April 1, 2008 Go back to basics mang. Does it have spark? Does it have fuel? Does it have compression? My bet is a fuel supply issue. Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted April 1, 2008 Author Share Posted April 1, 2008 its got fuel in tank... not too keen on opening up the lines to check, pretty sure its got compression / will try turn crank with a spanner with trans in "N" im thinking spark Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted April 1, 2008 Author Share Posted April 1, 2008 yeup, def got compression up in that bitch how can i check if petrol is getting to injectors? is there an easy way (Read: I have fuck all tools) Quote Link to comment Share on other sites More sharing options...
jendashjen Posted April 1, 2008 Share Posted April 1, 2008 How much fuel is it showing? Quote Link to comment Share on other sites More sharing options...
Unclejake Posted April 1, 2008 Share Posted April 1, 2008 yeup, def got compression up in that bitchhow can i check if petrol is getting to injectors? is there an easy way (Read: I have fuck all tools) Crack an injector nut partly open (if you can get to them) and have someone crank the motor over. If there is fuel there (unlikely) then it will spray around a bit. Do the same with a sparkplug out first though - make certain the sparkplug is grounded to the motor Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted April 1, 2008 Author Share Posted April 1, 2008 How much fuel is it showing? I put 7 bux worth in it this morning to be sure that there was some in there yeup, def got compression up in that bitchhow can i check if petrol is getting to injectors? is there an easy way (Read: I have fuck all tools) Crack an injector nut partly open (if you can get to them) and have someone crank the motor over. If there is fuel there (unlikely) then it will spray around a bit. Do the same with a sparkplug out first though - make certain the sparkplug is grounded to the motor sparkplug out but grounded ie. touching block? Me = dont have sparky plug removal socket me also = home alone will try find injector nut Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted April 1, 2008 Author Share Posted April 1, 2008 Do the same with a sparkplug out first though Whys this? Sorry for being noob as fuck, but usually when something breaks i just chuck a different motor in Quote Link to comment Share on other sites More sharing options...
Unclejake Posted April 1, 2008 Share Posted April 1, 2008 ^ have you got a spare sparkplug? Quote Link to comment Share on other sites More sharing options...
Spencer Posted April 1, 2008 Share Posted April 1, 2008 theres no injector nut there o-ringed in place, take off the return fuel line its the one thats just hose clamped to the fuel rail get some one to crank it and sit it in a jar should come out pretty quick not a dribble. Then just stick an old plug on the rocker cover or pull the lead back to expose the steel and hold it slightly above the head do for each plug / test the coil first pretty sure it will have fuel uj the fuel pumps are pretty sweet on these things Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted April 1, 2008 Author Share Posted April 1, 2008 any type of sparkplug? Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted April 1, 2008 Author Share Posted April 1, 2008 / u wana give me a hand spank? im home alone so hard to get some1 to help stz / will giv box of piss Quote Link to comment Share on other sites More sharing options...
Spencer Posted April 1, 2008 Share Posted April 1, 2008 ^ not really tonight feeling fucked but keen for tomorrow maybe. could be keen for tonight if you take me out for a dinner date Quote Link to comment Share on other sites More sharing options...
Unclejake Posted April 1, 2008 Share Posted April 1, 2008 If you have no tools and can get someone to give you a hand and the fault is now hard (i.e. the car won't go at all) then grab a can of engine start and try cranbking the motor over when someone is spraying engine start into the throttle body. If it goes then you know it is fuel. Sounds like Spencer knows his way around these thing a lot better than me but Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted April 1, 2008 Author Share Posted April 1, 2008 Keens for date if we skip dinner and just have the seks / yea tomorrow night, finish work at 5 / home at 5.30 could pik u up on way if ur keen? Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted April 1, 2008 Share Posted April 1, 2008 Ok, heres what your doing 1. go slam some mechanixs daughter. 2. Tell her you love her if her daddy check out your car 3. ???? 4. Profit Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted April 1, 2008 Share Posted April 1, 2008 although, upon saying that, If its as much as a whore as you are, It proboably has Aids Allan Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted April 1, 2008 Author Share Posted April 1, 2008 so spencer came and had a look. he found that: 1: my dizzy cap was fukzord / still had good spark 2: no fuel getting to injectors So ill grab new cap n fuel filter tomorrow n we will go from there /i wish it had aids Quote Link to comment Share on other sites More sharing options...
fuel Posted April 1, 2008 Share Posted April 1, 2008 maybe try putting more than $7 into it you poor cunt, that's like not even 4L. It could still be below the fuel pickup in the tank. Also, that silver box with heatsink behind coil is a ballast pack for the injectors I'm pretty sure. Quote Link to comment Share on other sites More sharing options...
