twosmoke
Um. Cut a hole in firewall and bellhousing, and draw a dot on the flywheel... then count how many times it's going round.
In other words, er, no.
Other option would be a kitset from Jaycar electronics for one of their digital tacho's, I assume they still make them and if you're ok with a soldering iron they're a doddle to make :)
My full in dash autometer setup was around $1000
Includes:
Tach
Speedo
Oil press
Oil temp
Boost
Water temp
Fuel
Those Jaycar digital things is also what I was going to mention.. they are cheap as too... OR.. Jaycar also make a rev limiter.. yuou could just set that to 8k then youll never go over it?
Yea other option as richie has said is find a starlet sprint with the same style dash an use the whole instrument cluster. I didnt have any luck looking for one, the drop hatch starlets have a square-ish dash different to that of the earlier ones
