Anybody got experience with viscous LSDs?
cubastreet
I have 2 viscous LSDs, both I think out of turbo legacies.
The first one I bought off tardme and it had been overpowered and the washers that the little spider gears bear against had broken up.
When I put a pair of stub axles in the diff centre I can slowly turn it by hand.
The 2nd one (thanks again jase) will only turn if I put one end in a vice and put a screwdriver through the stub axle in the other end and then it just turns very slowly.
Can anybody tell me if the first centre is stuffed? or is the 2nd one too tight?
