OSC Posted July 8, 2007 Share Posted July 8, 2007 so i just got all my 4agte and link and crap. but it doesnt have a tps wired up no plug and no wiring to the computer. thats not right is it ive got a link V2 or 3 i think the guy i bought all my stuff off said it was the same any help appreciated Quote Link to comment Share on other sites More sharing options...
Goat Posted July 8, 2007 Share Posted July 8, 2007 Hey boe. My Link doesnt have a TPS. Its just runs of crank angle sensor, MAP and temp. I do want to connect up the TPS at some stage but the motor runs fine without it. I dont see how it does but it does Quote Link to comment Share on other sites More sharing options...
kpr Posted July 8, 2007 Share Posted July 8, 2007 yeh will run fine on map only. tps is only used for a few things on the old lems. idle control and stuff. nothing to do with the tune itself, unless your running tps only. or tps+map. map only will be the best mode for a 4agte. unless you have big cams. Quote Link to comment Share on other sites More sharing options...
mikuni Posted July 8, 2007 Share Posted July 8, 2007 or tps+map. map only will be the best mode for a 4agte. unless you have big cams./quad throttles. We can't get much vacuum or consistant readings from my setup so map sensor see's nothing. Need to tune it on TPS stz. Engine will run better with TPS connect I think. Quote Link to comment Share on other sites More sharing options...
OSC Posted July 8, 2007 Author Share Posted July 8, 2007 sweet so it will run fine thats sweet then thought i betta get my facts straight before i hassle the guy i bought it off. um also does anyone have a wiring diagram for a v2/v3 link computer running a 4agte with dizzy because i cant seem to get the website link to work properly and i may have to dissasemble some of the wiring loom to tidy it up and get it to fit nicely in my car thanks.. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted July 8, 2007 Share Posted July 8, 2007 down load the manual for the computer from da link website. will have pinouts in there. Quote Link to comment Share on other sites More sharing options...
kpr Posted July 8, 2007 Share Posted July 8, 2007 heres the bits you wont get from downloading the manual. the colours could be diffrent tho. so be carefull there Quote Link to comment Share on other sites More sharing options...
OSC Posted July 8, 2007 Author Share Posted July 8, 2007 my igniter olnly has 3 terminals Quote Link to comment Share on other sites More sharing options...
kpr Posted July 8, 2007 Share Posted July 8, 2007 non toyota one? toyota ones suck anyway. Quote Link to comment Share on other sites More sharing options...
