escort mk1 Posted April 12, 2007 Share Posted April 12, 2007 Whats involved in re-studding a mk1 escort with longer studs so my minilites will fit on? Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 12, 2007 Share Posted April 12, 2007 just smack out the old ones and put in new ones? Quote Link to comment Share on other sites More sharing options...
thminiman Posted April 12, 2007 Share Posted April 12, 2007 USE A COPPER HAMMER Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 12, 2007 Share Posted April 12, 2007 a copper hammer would get fucked up wouldnt it? Quote Link to comment Share on other sites More sharing options...
avenger79 Posted April 12, 2007 Share Posted April 12, 2007 TAKE THEM TO AN ENGINEERS SHOP,THEY WILL WACK THEM OUT AND PRESS NEW ONES IN. MIGHT WANT TO TRY A FEW PLACES FOR QUOTES THOUGH. Quote Link to comment Share on other sites More sharing options...
thminiman Posted April 12, 2007 Share Posted April 12, 2007 a copper hammer would get fucked up wouldnt it? NAH THERE PRETTY STURDY CUNTS PLUS WITH A WHEEL NUT ON THE STUD IT'D BE SWEET Quote Link to comment Share on other sites More sharing options...
sholdowa Posted April 12, 2007 Share Posted April 12, 2007 You could use group 4 studs and mod the wheels. But as well as that being well expensive, they had a reputation for coming loose. But as already mentioned, they're a push fit in a star shaped hole. Dunno what you'd get longer studs off, though. Quote Link to comment Share on other sites More sharing options...
davidian Posted April 12, 2007 Share Posted April 12, 2007 theres a couple places up here that wholesale them. you just take your studs in and get something with the same shank thats longer and more common thread. dunno bout chch Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 12, 2007 Share Posted April 12, 2007 Does this always happen with super/mini lites and escorts? How much short are they? Quote Link to comment Share on other sites More sharing options...
davidian Posted April 12, 2007 Share Posted April 12, 2007 other rims too depending on design and offset. my new rims only have 2-3 turns of the nut on std. studs Quote Link to comment Share on other sites More sharing options...
Jebus Posted April 12, 2007 Share Posted April 12, 2007 Big center punch in the middle of the stud, smack it. Quote Link to comment Share on other sites More sharing options...
escort mk1 Posted April 13, 2007 Author Share Posted April 13, 2007 Yea the studs are quite a bit too short they only just out of the mag and i can hardly even start a wheel nut on them. Il just my car on the road with hubcaps to start of with and then i try sort something out. the minilites are just 13 inch and i was told the were 5.5 inch wide but im sure they are wider. is that measurement jsut from the outside of the rims? Quote Link to comment Share on other sites More sharing options...
davidian Posted April 13, 2007 Share Posted April 13, 2007 should be stamped on the rim boe Quote Link to comment Share on other sites More sharing options...
sholdowa Posted April 13, 2007 Share Posted April 13, 2007 I think that's why the original 4 spoke RS alloys had nuts that went a long way into the wheel. Quote Link to comment Share on other sites More sharing options...
Jebus Posted April 13, 2007 Share Posted April 13, 2007 5.5" might be jj which is from bead to bead, can only be measured with the tyre off, if you measure from side to side it will probaly be about 6.5" Quote Link to comment Share on other sites More sharing options...
Ke36 Posted April 13, 2007 Share Posted April 13, 2007 repco and stuff can ord4er in new studs there like 10-20 bucks each though ends up getting pricey Quote Link to comment Share on other sites More sharing options...
davidian Posted April 13, 2007 Share Posted April 13, 2007 repco and stuff can ord4er in new studs there like 10-20 bucks each though ends up getting pricey thats why you go and pay $2 ea if you know where Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 13, 2007 Share Posted April 13, 2007 yeah Davies Holden bring them in, thats where I got mine from, the guy had to muck around for agers trying to find something to match though. To get a wof your required to have certain length studs/threads etc, but with so many people putting covered nuts on you cant tell, and wof men never undo the nut and see, I got told by the guy at suspension tech that mine were too short Quote Link to comment Share on other sites More sharing options...
davidian Posted April 13, 2007 Share Posted April 13, 2007 davies holden actually. seen it in your post ages ago. got mine from there, good cunts etc, took 5 mins to measure stud/hub and look trough catalogue but yuh if you cunts want something from schoies let me know, i got a mate there in parts/apparel Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 13, 2007 Share Posted April 13, 2007 changed name to stop confusion Quote Link to comment Share on other sites More sharing options...
