J2Racing Posted January 4, 2007 Report Share Posted January 4, 2007 I'm building up What a MKI V6 Capri. I was planning to run a Tripple carb set up but the deal to get it custom built has fallen through. Anyone know of a local supply for under a kidney. Burtons sell one but the 600 pounds is what I plan to spend on the engine. in kiwi money. I've hear of running holleys. I can get a 350 cheap. Any ideas please. Sorry don't want injection or forced induction I want to stay retro looking. Quote Link to comment Share on other sites More sharing options...
RT Posted January 4, 2007 Report Share Posted January 4, 2007 I think finding a triple carb manifold for an essex over here pretty difficult dude... Quote Link to comment Share on other sites More sharing options...
excort Posted January 4, 2007 Report Share Posted January 4, 2007 i rember seeing a high rise manifold with a 4 barrel on it before on one hard to come by tho id say Quote Link to comment Share on other sites More sharing options...
J2Racing Posted January 4, 2007 Author Report Share Posted January 4, 2007 There about trouble is most are for german/yank cars. May just have to ply my mate with some more beers Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted January 5, 2007 Report Share Posted January 5, 2007 there was a triple 32/32 weber manifold available try redline go to a v8 shop buy a holley 1 inch spacer cut the top off your old manifold the weld the holley spacer on then go for a 390d/p holley which is a 4 barrel Quote Link to comment Share on other sites More sharing options...
J2Racing Posted January 5, 2007 Author Report Share Posted January 5, 2007 there was a triple 32/32 weber manifold available try redline go to a v8 shop buy a holley 1 inch spacer cut the top off your old manifold the weld the holley spacer on then go for a 390d/p holley which is a 4 barrel I know the part your talking. Thats what I'm thinking of doing. Alot of jet boats used to use holleys just not sure how it will work on a road car. Few red necks using them to. Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted January 5, 2007 Report Share Posted January 5, 2007 mate did said coversion on his manifold worked mint looked almost factory. the worst thing people do is over carb them some drop kicks put a 600 holley on em . its only 3lts even with a big cam ,ported heads headers and a big bore a 390 is HEAPS. i only had a 465 on my chevy v6 and that was making about 320hp a 600 made it run like a dog down low but the 465s smaller venturis speed the airflow up making it way more responsive Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted January 5, 2007 Report Share Posted January 5, 2007 mate did said coversion on his manifold worked mint looked almost factory. the worst thing people do is over carb them some drop kicks put a 600 holley on em Have you seen the pinto manifold for the 4 barrel holley? ....I still laugh when I see that Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted January 5, 2007 Report Share Posted January 5, 2007 I'm building up What a MKI V6 Capri. I was planning to run a Tripple carb set up but the deal to get it custom built has fallen through. Anyone know of a local supply for under a kidney. ' Good luck on that one.... try the zepher club (they ran the Essex didn't they?) Burtons sell one but the 600 pounds is what I plan to spend on the engine. Try http://www.teamblitz.com I know Norm has 2.8L parts but not sure about parts for the Essex as they didn't get it in the US IIRC. I've hear of running holleys. I can get a 350 cheap. Any ideas please. Sorry don't want injection or forced induction I want to stay retro looking. Throttle body injection looks retro, I keep getting people ask me what carb or tell me that it's not injected Quote Link to comment Share on other sites More sharing options...
J2Racing Posted January 5, 2007 Author Report Share Posted January 5, 2007 Yes Zephyr used the Essex. It was the first V6 put into production in the world. The 2.8 is the german motor much like the 2.3 in the cortina, but much better. I love the look of your injection but at this stage I want to try the carb method. Not sure on running a 4 barrel on a six. Will I need a plenum chanber or something because it's uneven. I could be wrong but someone said a twin throat or triple carbs are better because they are both divisable buy the number of cylinders. This could all be BS in which case I'll crawl back in my cage. Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted January 5, 2007 Report Share Posted January 5, 2007 its not bs dude but it doesnt make f all differance its no diff than a two barrall carby on the stocker. when ya cut the top off the stock manifold it becomes an open plenum. when u combine an engine with the correct size carby the intake pulses will easily draw the air\fuel mix to the right port. 3x2 barrel carbs simply position the venturi closer to the port it may add slightly better throttle responce but you would be pretty hard pressed to notice it. imagine a holden or valiant straight 6 with a single 4 barrell manifold thats a long way to the front and rear ports but they still make heaps of power. when u have a big duration camshaft and ported heads with a carb thats too big the intake pulses are weak and the airflow is slow the small airholes and passages in the carb dont pick up the intake pulse thus the throttle responce is shit until you have a few revs on board. with the correct size carb you still have good air flow thru the carb makeing everything work properly. its all about air speed. Quote Link to comment Share on other sites More sharing options...
J2Racing Posted January 5, 2007 Author Report Share Posted January 5, 2007 Thankyou I kew someone would know. Quote Link to comment Share on other sites More sharing options...
Mr Revhead Posted January 6, 2007 Report Share Posted January 6, 2007 just stick a quad cam from a "cologne" capri in it have you asked any one in the capri club? i wish i still had my mk1 Quote Link to comment Share on other sites More sharing options...
J2Racing Posted January 6, 2007 Author Report Share Posted January 6, 2007 Hadn't thought about the quad cam. I'll pop down to the dairt and get one. Havn't talked to any one in the club no as I have enjoyed many dealings with it's members. Quote Link to comment Share on other sites More sharing options...
Mr Revhead Posted January 7, 2007 Report Share Posted January 7, 2007 i know of some one with a couple of those engines id also suggest trying the UK capri club. im sure some one will have one for a decent price Quote Link to comment Share on other sites More sharing options...
J2Racing Posted January 7, 2007 Author Report Share Posted January 7, 2007 i know of some one with a couple of those engines Then you know the location of the other two that came into the country as far as I'm aware only two came into the country. Well thats race engines. Guess there are a few RS3.1 motors floating about. Quote Link to comment Share on other sites More sharing options...
Mr Revhead Posted January 7, 2007 Report Share Posted January 7, 2007 there was a collection of parts/engines in twizel of all places. they were sold to a guy in hamilton. cant say exactly how many, but i think its more than two. but i could be wrong. its not the guy who owns paul faheys (iirc) old race car either. hehe shouldnt be too hard to work out who it is Quote Link to comment Share on other sites More sharing options...
J2Racing Posted January 7, 2007 Author Report Share Posted January 7, 2007 I know who owns the fayhe car. As it has been in the south island for a good many years. In fact possibly since paul sold it. It was not the car burnt out at tertonga. I think that was the haliday car which of course was not a genuine car. It was a build up with a kitted motor. That engine is being used to restore the fayhe car. Are you sure they are the DOHC essxex and not the granda motor. Had someone try and sell me a DOHC granda motor once. Quote Link to comment Share on other sites More sharing options...
Mr Revhead Posted January 7, 2007 Report Share Posted January 7, 2007 granada? do you mean colonge? the essex is often mistakenly called a grenada, one of those 24v colonges from a scorpio would be cool. didnt think they put a 24v in a granada? i havnt personally seen them, but i have no reason to doubt they arnt what i was told they were. ill find out more Quote Link to comment Share on other sites More sharing options...
J2Racing Posted January 7, 2007 Author Report Share Posted January 7, 2007 I know what your saying about meatheads calling essxe granda trademe is full of them! As far as I'm aware the very late granda which is XD falcon shape used them. As far as I'm aware the only car the used the essex dohc was the RS3.1 I thought the scorpio was a german modle and fitted with the granda motor. Quote Link to comment Share on other sites More sharing options...
