GTOld Posted August 29, 2006 Share Posted August 29, 2006 Hello, I have just fitted a single Weber DCOE to my 2litre Astron 4G52. What do I need to do to the dizzy now that there is no vac advance port on the DCOE? Bit green on this subject. Any advice would be great. Cheers, GTOld Quote Link to comment Share on other sites More sharing options...
Ogre Posted August 29, 2006 Share Posted August 29, 2006 i did the same conversion with my 4g63, but there was a vacume port on the carb. i remember reading somthing about someone with the same problam and i think they just ended up making there own. I think it would need to be as closs to the base of the carb after the throttle body if you get what i mean...... Quote Link to comment Share on other sites More sharing options...
Raizer Posted August 29, 2006 Share Posted August 29, 2006 Or you could get your dizzy regraphed(?) so you dont have vac advance at all Quote Link to comment Share on other sites More sharing options...
Defcon Posted August 29, 2006 Share Posted August 29, 2006 You could have a port put on the manifold for vac -ad, or just advance the dizzy a few degrees, say 2-4 not sure about mitsi's but thats what i did on my engine. Quote Link to comment Share on other sites More sharing options...
GTOld Posted August 30, 2006 Author Share Posted August 30, 2006 Thanks guys will try advancing it a bit and see how it goes before drilling any new holes in the manifold or body. Anyone bother plumbing back in the low load crankcase breather? I suspect if this is left open then the engine bay is going to get a bit oily. Should have everything sorted out next week so i'll let you know if I am successful. Cheers for now, GTOld. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted August 30, 2006 Share Posted August 30, 2006 Thanks guys will try advancing it a bit and see how it goes before drilling any new holes in the manifold or body.Anyone bother plumbing back in the low load crankcase breather? I suspect if this is left open then the engine bay is going to get a bit oily. Should have everything sorted out next week so i'll let you know if I am successful. Cheers for now, GTOld. generally people don't change the crankcase breathing system form factory. usually if they do then they run the breather to a catch tank, then have a small filter to catch any mist that's not been trapped in the catch can..... Quote Link to comment Share on other sites More sharing options...
lowlancer Posted August 30, 2006 Share Posted August 30, 2006 Change carb eh. Probably easier in the long run. When I converted my 4G63 SOHC to 32/36 it was literally bolt on with the adaptor, then light tuning. Quote Link to comment Share on other sites More sharing options...
