escort 2l front sus
jaymz
The actual 1300 strut and the 1600 strut is the same apart from mk1/2. The sport, ghia or capri discs will be bigger than escort ones. Or if the discs are vented then they most likely are capri. measure the disk diameter.
For the springs you may want to put a slightly heavier weight spring in because the engine will be abit heavier. Up to you.
  • 4 weeks later...
Ha anybody actually done this themselves or just talking from what they have "heard". Because If it's bouncy at the front then i don't want that I am rebuilding the car so I don't mind spending a bit on the suspension if I know it's going to ride well. I will proberlly lower it by 2 inches
At the mo I have 2l in mine with adjustable suspension. the springs in the setup are 10inch long, 2 and a quarter internal diameter and are suposed to be 160lbs rate. They are way way to hard. I would suggest 120-140lbs if you are going that far into it.
If you dont mind spending some coin get some new shocks from repco or wherever. Buy some new RS2000 springs from here https://www.burtonpower.com They are rs2000 springs and are 145lbs. Now also get the rear leafs reset with maybe an extra leaf and new rear shocks.
You also have to remember that better handling is going to come with a harder ride than standard.
I gues what I am trying to say is that a suspension upgrade is not absolutly needed but if you did want to upgrade then the above would be the best choice really.
