excort Posted November 6, 2005 Share Posted November 6, 2005 hey i was wondering if someone could give me some ideas on difs i could put in to my 76 mk2 escort it was a auto 1300 but now its a 2ltr pinto 5spd ive been told if i change it i would get quite a improvement ?cheers Quote Link to comment Share on other sites More sharing options...
atropine Posted November 6, 2005 Share Posted November 6, 2005 depends on what ya want.. lsd or not for a start? and then theres ratio choices.. Quote Link to comment Share on other sites More sharing options...
Toucan Posted November 6, 2005 Share Posted November 6, 2005 Yea depends on what you want. 4.1s came out in the vans an 1100s i think, they will give you quick get up an go 3.89s or something are in your common 4dr or non sports i think 3.54s are found in sports and ghias, get this if you have a 4spd and want the ability to cruise at 100kms at lower revs Dunno much about non escort diffs myself Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted November 6, 2005 Share Posted November 6, 2005 DELETED Quote Link to comment Share on other sites More sharing options...
excort Posted November 6, 2005 Author Share Posted November 6, 2005 well id like a lsd but im guessing ill have to pay a fair bit to get one i want something thats gona give me some low down power ay for take off caurse i have the 5th gear to make up for it any idea what kinda dif mine would be Quote Link to comment Share on other sites More sharing options...
atropine Posted November 7, 2005 Share Posted November 7, 2005 my belief was the 4.1 was the common one for most 4drs.. since youve got a 5spd.. a 4.11:1 aint a bad option.. generally better pickup than a 3.54.. Quote Link to comment Share on other sites More sharing options...
Stacov Posted November 7, 2005 Share Posted November 7, 2005 my belief was the 4.1 was the common one for most 4drs..since youve got a 5spd.. a 4.11:1 aint a bad option.. generally better pickup than a 3.54.. mine is running the 4.1 diff with my pinto 5spd makes 1st and 2nd pretty short atropine can vouch for that yep good pick up tho Quote Link to comment Share on other sites More sharing options...
Toucan Posted November 7, 2005 Share Posted November 7, 2005 Hmm yea atro might be right I was just going by what I read in the manual ages ago, that would explain my high revs at 100 and good pick up haha. Is there any way of telling by looking at the diff? Edit: Looking at the manual, it goes by engine not by number of doors, who would of guessed 1100 sedans had 4.125s 1100 vans had 4.125 or 4.44 1300 LC had 3.89 1300 HC had either 3.89 or a 4.44 or a 4.125 for the van 1300 sport had a 4.125 1300 heavy duty from a van had a 4.125 1600 sport had a 3.54 Quote Link to comment Share on other sites More sharing options...
Gaz Posted November 7, 2005 Share Posted November 7, 2005 How wide (drum to drum) is an escort diff?Callum 1355mm Im pretty sure. Measured it a few months back. Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted November 7, 2005 Share Posted November 7, 2005 DELETED Quote Link to comment Share on other sites More sharing options...
davidian Posted November 7, 2005 Share Posted November 7, 2005 what sort of coin are you looking at to shorten the housing? ive had axles done before so thats not too much of a worry but not shure on the main bit Quote Link to comment Share on other sites More sharing options...
peteretep Posted November 7, 2005 Share Posted November 7, 2005 a guy i know who has a race escort runs a 4.1, he has run most ratios and a lsd falcon diff but he said that the 4.1 is the best and that a falcon diff is too heavy and probably excessive anyway Quote Link to comment Share on other sites More sharing options...
atropine Posted November 7, 2005 Share Posted November 7, 2005 my dads old mk1 had a 5.1:1 atlas diff.. mwhahahaa Quote Link to comment Share on other sites More sharing options...
excort Posted November 7, 2005 Author Share Posted November 7, 2005 hey thanks for all the info guys so you reacon i should just stick with the dif i have? i think a falcon dif would be going abit overboard lol would it be posible to get a lsd head out of something and put it in mine ? Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted November 7, 2005 Share Posted November 7, 2005 When i had the 5 spd in my car with 4.1 diff i was doing 3 thousand RPM at 100 ish k's, with the 4 speed and 3.54 i do 3200 at a hundy. On a 1600. Just some useless info. Quote Link to comment Share on other sites More sharing options...
atropine Posted November 7, 2005 Share Posted November 7, 2005 yep.. and 5spd 3.54 is around 2700 i think.. Quote Link to comment Share on other sites More sharing options...
Gaz Posted November 7, 2005 Share Posted November 7, 2005 a guy i know who has a race escort runs a 4.1, he has run most ratios and a lsd falcon diff but he said that the 4.1 is the best and that a falcon diff is too heavy and probably excessive anyway What type of racing does he do? Quote Link to comment Share on other sites More sharing options...
Toucan Posted November 8, 2005 Share Posted November 8, 2005 Ok I've managed to confuse myself... I thought to work out your diff ratio, you jack the car up and turn the driveshaft, and the wheel would do one revolution for say 3.89 turns, meaning that you had a 3.89:1 ratio diff... Cause i just did that, put a mark on both the driveshaft and the tyre an I got exactly two turns of the driveshaft would make one turn of the wheel, meaning I have a 2:1 ratio diff, which cannot be right Can someone please explain for me Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted November 8, 2005 Share Posted November 8, 2005 DELETED Quote Link to comment Share on other sites More sharing options...
Toucan Posted November 8, 2005 Share Posted November 8, 2005 Ahhhh ok cheers for that Quote Link to comment Share on other sites More sharing options...
